Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > Hammer Performance
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
0 1977 Bright Blue
Last Post: ericfreeman
Last Post: jammantoo
0 Value of a Boattail?
Last Post: valvebeater
Last Post: lugster
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
Last Post: gravydog
Closed Thread
Old 8th March 2012
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Default HAMMER Head Porting
This thread is just to give people a little more background on the head porting process at HAMMER PERFORMANCE. This is a process that has been under continual development and refinement since 2003 when I bought my first CNC machine.
HAMMER Dan (Dan Norlin) now owns all the head porting equipment, fixtures, CNC machine, CNC programs, and flow bench, and he's the expert on head porting. So who is Dan Norlin?
If you happen to have a Screamin Beagle catalog from 2004, you'll find his ugly mug in it, for winning the AHDRA High Stakes Shootout in 2003. He's smiling because that was a $12,000 payday. I'd smile too! He's actually won the shootout twice and been runner-up twice. So to say HAMMER Dan is an accomplished drag racer is a hell of an understatement. See this page for a demonstration of HAMMER Dan's drag racing prowess.
Dan was one of my customers back then and we spent a lot of time together, mainly in the shop, working on his engines together. Obviously he came to know a lot about what we do and how we do it.
When I shut down that business, HAMMER Dan ended up with the machine shop side of it, and my salesman ended up with the retail side of it. HAMMER Dan is quite the accomplished head porter and engine builder. In fact, I have him do all the race heads for my Bonneville bikes, and he's been doing them for me for several years now. Many of the Bonneville records I've set were done with his head work. As most people know, there's another well-known shop that also benefits from HAMMER Dan's expertise.
From the day he bought the machine shop, HAMMER Dan and I have continued to develop the processes and CNC technology. Basically, we've tried to automate as many steps as we can. Anything you can do on a CNC machine will come out with more consistency and quality than doing it by hand, that's just a fact. But the CNC has limitations as well, limitations we've worked very hard to overcome. Dan is the expert on head prep and I'm the code monkey and together we work to make the best process we can, so that we deliver the best product we can.
This is one of the first steps to get done to any set of heads. Once they're stripped and inspected, they're put into the 4-axis CNC machine in this position to get the seat work done.
Well, there are a lot of possibilities on this step. What size valves are the heads getting? What's the current seat i.d.? What kind of head is it? Is it a front or a rear head? Will it need new seats?
The problem here is that there are SO many possibilities, that keeping a separate CNC machining program for every one of them would be next to impossible. You'd have thousands of programs to choose from, and you'd have an error prone process. So here's our solution:
HAMMER Dan and I developed this program specifically to perform all seat operations. Basically, you enter all the information, and hit the "GENERATE CNC CODE" button down at the bottom of the screen, and the program goes off and writes the CNC program and then offers to send it to the machine. HAMMER Dan then punches a few buttons on the machine to get it ready, and hits OK, hits the "Start" button on the machine, and off it goes.
The top line in this program takes in info about the customer, as the program keeps a log of everything done to every set of heads. Head type and which head (f or r) is chosen next.
Then on the left you have everything to be done to the intake seat and on the right is the exhaust seat. You typically start by doing a "locate" operation. Since heads vary from one to the next, this step allows you to use an indicol to precisely locate the center of each valve. Once it's located you then set it up to do the cuts. You can cut and shape the seat, blend and unshroud it into the chamber, remove the seat completely, and/or cut a new seat pocket whatever size you want.
When HAMMER Dan cuts the seats at this step, he intentionally leaves a little material in them, because later he'll cut them again with the actual guides. But for now, he rough cuts them in, then removes the stock guides, and moves on to cutting the ports:
Again in 4-axis mode, the machine cuts the ports to the proper size and shape. But just like the seat operations, there's a dizzying array of possible combinations in terms of what you want the machine to do. So naturally we created a program to sort this out:
This is our main porting program. But it actually does a lot more than just let you select operations. If you choose the "Sledge" mode as shown, the program allows you to enter application specific parameters, like the bore, stroke, rod length, target power peak rpm, and cam timing. The program then goes off and does a bunch of math to figure out the ideal port size, and dynamically generates a CNC porting program to cut the port that size. This overcomes one of the big, big limitations of CNC porting, the ability to custom tailor the port to the application. It's the best of both worlds, you get the accuracy and repeatability of CNC with the custom capability of hand porting. I'm not aware of any other shop that has anything else like it.
Once that's done, HAMMER Dan does the hand blending. There's a fair bit of variation from one head to the next, and also there are some areas in the port where the CNC can't reach well. Dan is very talented and experienced at smoothing the variations and shaping the places the CNC can't reach.
Once the ports are right, Dan presses in new guides, sizes them for proper stem clearance, runs them through the machine again to get the seats to the final size with the final guides, and then puts the final valve job onto the seats:
During this step he also sets the stem protrusions for the correct geometry and proper valve to valve clearance. We use specially shaped seat cutters of our design on the seats themselves. We've found this process to work much better than using stones or other methods. The seat profiles for the two valves are very different as well, as their functions are different. For example, the exhaust seat has a much wider 45 degree area because one of the important functions of the exhaust seat is to pull heat away from the valve.
Any chamber work the heads need is performed as well:
This head is getting an angled squish band in the CNC machine.
And you guessed it, we have a program for that, too:
This program is also used for cutting the deck, which goes hand in hand. Ignore the valve seat stuff, we created the aforementioned program and no longer cut seats with this program. Also note the mentions of external head drains, the programs do this for us as well.
HAMMER Dan will iterate on this step until he gets the chamber size right where he wants it, to give the customer the compression ratio he wants:
And of course, EVERY head gets flow tested before it leaves the shop:
Finally, once the heads are perfect, HAMMER Dan assembles them with the finest hardware available:
The springs are of course shimmed as needed for the proper installed height, to give the required seat pressure and travel.
And finally the heads are ready to go back to the customer:
This process has served us well. HAMMER Dan runs hundreds of sets of heads through his shop every year, and has proven time and time again to deliver a superb quality product that performs exceptionally well. I'd wager HAMMER Dan has put more XL's over 100hp than just about anyone out there.
If you'd like to treat your heads to this process, give HAMMER Dan a call at 970-344-7120.
Click Here to Contact Me
Old 8th March 2012
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond repute
Damn... what an explaination! For those who do not understand CNC machines and programs, they are not as easy to work with as one might think. This thread shows how much thought and work went into doing just one phase of an engine build. I'm impressed!! I don't think I would want anyone else but Hammer or Dan do my heads!!!
Great write up and explaination!!!
Denny
Old 8th March 2012
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Great write up Aaron, thanks for sharing all that info.
Old 8th March 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
Wow, this is a cool thing to see for those of us who don't know a whole lot about porting heads and what goes into it. Thanks for the writeup!
Old 8th March 2012
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Great write up! I would just like to add "Hammer Dan" has answered every question I've had about my build.... Himself. It's really cool to be able to talk to the guy thats machining and assembling your parts. I can't wait to get my heads sent off!
"Only Fools Celebrate A Fool"
Old 9th March 2012
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
How do you deal with getting specific compression ratios vs different pistons?
Ed
The Only Y2K dual-set 883C
So Cal
Old 9th March 2012
aswracing's Avatar
Thanks guys ... glad to know y'all found it interesting. I could go into a lot more detail but that's the basic procedure. Not shown is the fixture and program used for operations done to the top of the head ... compression releases, dual plugging, and decking the rocker box surface. But that's all done with a similar CNC process as well.
This is a great question, thanks for asking.
For most jobs, we have data on the pistons, because most jobs use our pistons. So knowing for example the dome volume of the piston, and the desired compression ratio, we use this other program I wrote ...
... and we simply select the bore, stroke, plug in the dome volume, piston height, and gasket specs, and then we can easily see what the CR will be with any given chamber size. We iterate plugging in chamber sizes until we see the CR the customer wants, and that's what HAMMER Dan sizes the chamber to.
In those cases where we don't have specs on the pistons, we need to go through a process to measure them. Basically what we do is install the top ring, pack grease around it to seal it up, insert the piston into the cylinder from the top, and slide it down the bore 1 inch. Then using the same burrette that's shown in the picture of the chamber cc'ing earlier, we measure how much volume there is in the cylinder above the piston.
In the program shown above, notice that instead of entering dome volume, you have the option of entering 1" down volume. We plug in the 1" down volume there and the program bases it's calculation on it instead.
Old 28th April 2015
aswracing's Avatar
Default A little history lesson
In light of some misinformation being spread elsewhere on this site, I'm going to give a little factual history lesson, expanding on the short version I gave in the opening post to this thread. I really don't want to do this, but the alternative, letting bad information stand unchallenged, is worse. I'm not going to allow discussion on it though. This is going to be pure facts, none of it is open for debate.
Nallin Racing's CNC head porting process was developed by me personally, including all the fixtures, tooling, and CNC head porting programs, among other things, some of which is described in this thread. I also personally built and campaigned the bikes that set so many land speed records.
I dissolved Nallin Racing in 2006. The machine shop, including the head porting CNC machine and all the port designs and head porting technology described in the first post of this thread, were ultimately purchased by Dan Norlin, who formed a new machine shop company.
I continued to help him in his new venture, providing support and improving on the head porting process at his request. So the development of the process never really stopped.
In 2010, Dan formed HAMMER PERFORMANCE, as a new retail outlet for his machine shop services. By then, I had retired to a small town in Idaho. I really wasn't planning on getting involved, I wanted to retire.
But over the next couple of years, he gradually talked me into getting more and more involved. There was kind of a push-pull effect, too, but I don't want to get into it.
In the spring of 2012 I dove in full time. We moved HAMMER to the small town in Idaho where I had retired to in 2010, that was one of my conditions. So much for retirement!
At the time of the move in the spring of 2012, Dan Norlin ceased providing any machine shop services to anyone else.
Dan Norlin still runs HAMMER PERFORMANCE. He is the founder and president and runs the day-to-day operations. I help out with customer service, the web site, and R&D, in addition to running my own manufacturing business, and helping with my wife's business. I'm busier in retirement than I've ever been!
Bottom line, the porting process and port designs we have today at HAMMER, and described in this thread, are the direct descendants of the Nallin Racing porting process and port designs first developed by me starting in 2003, refined and developed and improved over the years to achieve new levels of performance. Over those years, this porting process has had more XL heads run through it than anyone else, and it's put more XL's over 100hp than anyone else. And for the last three years, HAMMER PERFORMANCE has been the only place you can buy this porting service.
So if you see someone else claiming to be Nallin Racing or claiming to sell the legendary head porting of Nallin Racing, well, they're not being honest with you. Nallin Racing was dissolved years ago, although the head porting process lives on and is available only from HAMMER PERFORMANCE, albeit modified and improved on greatly over the years.
In my best Paul Harvey voice, "And now you know the rest of the story"
Old 28th April 2015
WI_duker's Avatar
WI_duker WI_duker is offline
Sportster/Buell Year: 1988
Other Motorcycle Model: Blast
WI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond reputeWI_duker has a reputation beyond repute
Your tech support, customer service and commitment to honoring your promises are beyond reproach.
It's Hammer time
Closed Thread
