0 What's your helmet?
Last Post: MCCoy
Last Post: Zoharo
Last Post: Wharfcreek
0 04 sportster custom 883, turn signal module (TSM)
0 Silverado Power lock issues
0 C.O.B.B run west
0 no rear brake light
0 New England 2018
Last Post: tvon
Last Post: hscic
Last Post: groovemeisterus
Old 28th September 2005
vert306 vert306 is offline
Sportster/Buell Model: sporty XL 883/1200 con
vert306 is an unknown quantity at this point
Default Torque specs, diagrams or procedures, manual?
just wanted to know where i can get a spec sheet, or diagram of the sportster engine, that shows the torque specs for doing the heads etc etc. anybody have a copy or know where i can get some info? much appreciated. thanks.
Predator's Avatar
Predator Predator is offline
Senior Bike Builder
Sportster/Buell Model: NRHS 88" Custom
Predator is on a distinguished roadPredator is on a distinguished roadPredator is on a distinguished road
They're in the factory service manual. You can get one from your local dealer.
If you need anything in a hurry i'll look it up for ya
'02 883 Custom
NRHS 88" Stage III
ya i know the dealer has one, i was just wondering if anyone had a copy on their computer for torque specs etc. my buddy is doing a head gasket replace on his 1996, and i was trying to help him out with pertinent info...
Predator's Avatar
Senior Bike Builder
I have nothing electronic. I don't even think it exists but maybe someone here has scanned it to their PC.
Shu's Avatar
Shu Shu is offline
Other Motorcycle Year: 2007
If you are just wanting head torque procedure, here you go:
a. Tighten each head bolt to 96-120 in lbs (11-13 Nm)
b. Tighten each head bolt to 13-15 ft-lbs (18-20 Nm)
c. Loosen all head bolts.
d. Tighten each head bolt to 96-120 in lbs (11-13 Nm)
e. Tighten each head bolt to 13-15 ft-lbs (18-20 Nm)
Mark cylinder and head bolt shoulder with a line and
tighten bolts an additional 90 degrees.
Torque sequence for REAR cylinder (when looking down
at the top of the cylinder facing towards the front of
the bike).
1. UPPER bolt on LEFT side
2. LOWER bolt on LEFT side
3. UPPER bolt on RIGHT side
4. LOWER bolt on RIGHT side
Torque sequence for FRONT cylinder (when looking down
the bike).
1. LOWER bolt on LEFT side
2. UPPER bolt on LEFT side
3. LOWER bolt on RIGHT side
4. UPPER bolt on RIGHT side
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
Chris B.'s Avatar
Chris B. Chris B. is offline
Sportster/Buell Model: Ironhead 1000
Sportster/Buell Year: 1973
Chris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura about
Harley Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque.
Chris B. -'73 Ironhead
Chris B.'s Avatar
Default Just incase...
Old 29th September 2005
thank you very much for all the input. that's exactly what i needed.
Old 25th October 2010
skiponies's Avatar
skiponies skiponies is offline
Sportster/Buell Model: 883/1200 conversion
skiponies is an unknown quantity at this point
Been following this post since we are at a similar spot in top end repair. Put one side back together today. My husband says he feels that these values are too light. Any comments on why they wouldn't be tighter? J
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
These value's are straight out of the factory service manual. I wouldn't deviate from them. Does he think they should be tighter or less tight?
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
