Last Post: Grumpy-Biker
0 Salutations y'all
Last Post: Alias Bob
0 no rear brake light
0 67 Sportster build
Last Post: ldurmon
Last Post: geoff
Last Post: goblin_dust
0 What's your helmet?
Last Post: lucky23
Last Post: cotton1
Old 15th March 2012
Tater's Avatar
Tater Tater is offline
Sportster/Buell Model: 1200 C
Sportster/Buell Year: 09
Tater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to all
Originally Posted by joesporty View Post
I've got some time in with the bike on the lift spinning the bike tire while adjusting the belt to ride straight on the pulley only to find out that in order to do that i have to make the axle crooked..using the wire from the swingarm bolt to the axle method for alignment...mine rides exactly like yours and i have measured 20 times to make sure...
Yep, and I am thinking that things were squared up real good about 1,000 mi. ago when I installed a new tire, I checked and double checked, I just thought I might try to very easily tweek it a bit and see if it centered up...
I will first guage the axle to swing arm distance and if it don't look like I could give it a slight tweek without getting it off, then I won't... And +1 on the not too tight belt...
Thanks, and have a good one...Tater...
Sportster Owner/Rider since age 72...lol... Rider since Simplex...???
09-xl1200 "C" Vivid Black, Cast 19" Frt. Wh., Moded Stage 1+, X14iEDs, 29k + mi...
MicroTach +, Higher wider H-bars, Mustach bar Mtd. Hwy. pegs...
Viking Shock Cutout Saddlebags, Mustang Seat, Rear Mt. Signal Lt. Kit, SuperBrace...
