Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
Last Post: blindfredy
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
Old 8th January 2005
cderham's Avatar
cderham cderham is offline
Sportster/Buell Year #2: 2004
cderham has disabled reputation
Question '04 Wide Glide Conversion Kits?
Hey Guys and Gals,
I havn't been to the new site and just went through the whole register process..... But I was looking for the information on the old site on raked wide glide conversions for my wifes bike. Does some one still have all that info??? There was different site links, pics, etc..... I'm looking for 3 deg rake wide glide kit. High quality that will work on an '04 and keep the neck locking w/ internal stop.
Thanks in advance
Blu-Skyz,
Chris
HHahn001 HHahn001 is offline
Sportster/Buell Model: 1996 883/1200 XL
Sportster/Buell Model #2: E 1984 XL1000
HHahn001 is an unknown quantity at this point
Try Hawghalters.com..hope this helps
XLFREAK XLFREAK is offline
I have an accutronix with a 3 degree rake on an 05 which is the same as an 04. Personally I would only consider Accutronix or Hawghalters but there it is a little more involved than just installing the kit.
As for the locking steering, these kits don't come with this option but it could easily be done at a machine shop. Just make the spot where the pin goes and have a 1/4 inch hole drilled out. Personally I don't trust those steering locks after I looked over the service manual and saw how easy it was to remove them, I just use a padlock thought the rotor.
Moved On Moved On is offline
Is this the thread you were thinking about? It was from user mwachala in regards to the wide glide chopper kit front end that he put on his '04, I think his is more than 3 degrees though.
Edit: I forgot my manners...
Welcome to the forum !!!
Gary
Gone Gone is offline
These trees are available in polished, chrome or black anodised.
Billet triple trees are 34mm thick.
Designed to accept the stock rubber handlebar bushings. You can also choose to maintain or disregard the steering lock. The slot on the top tree is made to accept stock cables, so that you do not have to unassemble or modify them.
Kit includes wheel axle, necessary spacers and hardware.
Dual disc braking system configurations will require spacer.
Wide glide triple trees will fit all models XL from 1988 to 2005
Available in 0° or 4° degrees rake.
Old 25th January 2009
crowin's Avatar
crowin crowin is offline
crowin is on a distinguished roadcrowin is on a distinguished road
"Wide glide triple trees will fit all models XL from 1988 to 2005"
Guarantee these will not fit 2004 and up. there is a huge difference in the neck and frame on sportsters after 2003. i have had to return 3 frontends that were sold to me as for 2004 including everything. if someone has one on a 2004 that they recommend, then use that but dont use anything that says it will fit from 1988 - 2005. it wont. I used an old aftermarket front end and had to forgo the stops, my frame is the fork stop. truly tho if anyone knows where to get a wide glide for an '04 and up please tell me.
aloha,
chuck
To have a sense of humor you gotta have sense.
Old 29th January 2009
crowin's Avatar
Default oops
I Stand Corrected. Hawghalters Does Make Trees For 2004 And Up.
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Why are we digging old threads up from 4 years ago??
HHI or Hawg Halters makes tree's for all makes and models..from old to 09
Similar Threads
HHI Wide Glide Conversion with 4 Degree Rake slolane Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 24 13th September 2005 16:14
Accutronix wide glide conv w/ a wide glide wheel buckethead Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 1 21st April 2005 19:38
What is the benefit of a wide glide conversion? klown Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 2 29th March 2005 02:36
Wide glide conversion HotRodSporty Sportster Motorcycle General Discussion and Problems 26 31st January 2005 18:51
