0 What's your helmet?
Last Post: Jheitt
Last Post: hscic
Last Post: Hellbent_4
Last Post: MCCoy
0 The Welsh Way, 21st April 2018
0 Show your tank decals
Last Post: kap
0 Tuning
Last Post: XLXR
0 Spokes or Mags
0 New in NM
Last Post: spoon
Old 30th September 2005
hondo hondo is offline
Other Motorcycle Model: 2000 ZX12R/1998 T595
hondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura abouthondo has a spectacular aura about
Default Stage I XL1200R
My original post on this forum was "Painfully stock dyno run".
A couple of days ago I visited the dyno again with the following results:
74.0HP@6,100 rpm
Torque 76.9ft.lbs@4,500 RPM
A slight dip in the torque curve centered at 3,500RPM, probably exhaust reversion, torque was 70.0ft.lbs. or greater between 2,500RPM and 5,500RPM.
Air/fuel ratio on the 74HP run after the intial rich dip was between 13.0-13.6 until 3,200RPM when it dropped to between 11.6 and 12.8 for the remainder of the run.
My thoughts are, exhaust reversion from 3,000-4,000RPM and a 180 main jet that is too rich for this combination.
Present carburetor settings are: #45 pilot jet, 2 1/2 turns out on the mixture screw, two 0.022" washers under the needle, #180 main jet.
A 16.5HP increase thus far! The dyno operator stated they usually see 7-10 HP with stage I modifications.
Your thoughts?
Yellow Pearl 05 XL1200R, Mikuni 42, .551, Doherty AC, Golan FV, DTT, Modified SE mufflers
bshadbolt's Avatar
bshadbolt bshadbolt is offline
Other Motorcycle Model: Suzuki GSX750ESG
Other Motorcycle Year: 1989
bshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura about
I just did a baseline dyno on my '05 XL1200R Stg I yesterday.
We've got the same bikes. I love the Yellow Pearl.
76.1 HP and 81.5ft.lbs torque - great torque numbers and a nice convex torque line. I'm still playing with my jetting and hope to improve on this slightly.
Cheers,
Brett Shadbolt
'05 XL1200R - Pearl Yella
Motor: N4 cams, Python 2-1, Mikuni HSR42, RamFlo 400, TC88A Ignition
Handling/Comfort: Mustang Daytripper, Progressive 418HD's, Progressive fork springs, floating brake rotors, fork brace, 1200S bars
Aesthetics: chin spoiler, bikini fairing, front signal relocation
What settings are you using on your TwinTec ignition module? That will be my next step up the ladder purchase wise.
I might have to wait until after Christmas though, since my wife is having knee surgery soon.
You have no reversion problems with your SE II's! I had a slight dip of 2ft.lbs. in the torque curve from 3,000-4,000 centered at 3,500RPM. I thought this was interesting since the air-fuel ratio nosedived at 3,200RPM to 11.6 and stayed rich the remainder of the run.
I'm liking the sound of the SE II's better now after a 220 mile round trip to vist my parents in IL, 52mpg @75mph except for 20 miles in/out of town.
bshadbolt's Avatar
Twintec is currently at 2-3 but just got it and am still dialing it in.
I don't have any dip in the torque curve at all, pretty much a perfect convex. I've just bought a set of Python 2-1's and they should arrive in about a week, so will be atking the SE II's off soon. Once the 2-1 is installed and twintec/jetting is finished I'll do another dyno and let you know how it goes.
Cheers,
Brett
EC1250R's Avatar
EC1250R EC1250R is offline
EC1250R is on a distinguished roadEC1250R is on a distinguished road
Are you doing the proper 5th gear roll on method? Make sure you do it while riding, not on a dyno. The bike should be under real world conditions when adjusting the ignition curve. And remember if the bike feels stronger at a lower setting than a higher one, then the lower one is probably the correct one. The roll on method just alerts you to when the ignition is way to far advanced. Setting it on a hot day is also preferred. Another good trick is to set it while using lower octane gas. Your bike will really let you know the correct setting then! =)
Dyno sheet
I hope this works, I'll try it from work tonight.
starbuck's Avatar
starbuck starbuck is offline
starbuck has disabled reputation
You guys keep this stuff coming, it rocks. This is the meat and potatoes of this forum. I greatly appreciate you guys sharing your gear head knowledge.
Old 1st October 2005
Go to my gallery to see a copy of the dyno sheet.
http://xlforum.net/photopost/showpho...8&limit=recent
