Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 20th March 2012
Grim's Avatar
Grim Grim is offline
Other Motorcycle Model: Honda CBR 600 F4
Other Motorcycle Year: 2000
Grim is just really niceGrim is just really niceGrim is just really niceGrim is just really niceGrim is just really niceGrim is just really niceGrim is just really niceGrim is just really niceGrim is just really niceGrim is just really niceGrim is just really nice
Default Should there be no air in forks?
So I just installed a set of progressive springs in my Iron, huge difference, I no longer hear a clunk when I hit a bump and the bike feels like its actually absorbing the bumps.
Anyways, I was just thinking that when I put the fork caps on, I had the front end raised up, and was wondering if the fork tubes need to be bled somehow, or if air in there is ok? If they need to be bled, how would I go about doing it?
Thanks in advance,
Old 20th March 2012
Banned
You could do them in deep space in a vacuum, but why?
Old 20th March 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
You need to have air in your forks. Without the air, your forks would not compress. When you installed your springs you need to maintain a certain oil level measurement.
George
--Thomas Jefferson
Old 20th March 2012
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Impossible, physics dictate it with the general gas law.
Old 20th March 2012
Grim's Avatar
I guess if they were met to be bled they would have a bleeder screw at the top, much like brake lines do.
Hey you can ask stupid questions, or make stupid mistakes! I'd rather ask, its cheaper. lol
Old 20th March 2012
Ireeman's Avatar
Asgardian
Cavitation would still happen due to friction and enough heat.
Old 20th March 2012
Banned
Not if you brush at least 3 times a day!
Old 20th March 2012
Ireeman's Avatar
Asgardian
Uh huh......
One of these days harpo...pow zoom right to the last ring of Saturn.
BTW how did you find Venus, Jupiter and the Moon aligned this month... pretty cool eh?
Old 20th March 2012
Gcram399's Avatar
Grimm: Shared insight is what this forum is all about.
IREEMAN & ASOT's bantering always brings a bit of light to any thread. Glad to see you back Shelle.
Old 20th March 2012
Banned
Would that be inside or outside of casinni's division?
I found it to be quite nice, but not enough to try out my new camera on them
