0 900 heads contd..
Last Post: spacecoast
Last Post: wharg
0 Bars on C Riser?
0 Clutch Spring plate poll
Last Post: jammantoo
0 crack in head
Last Post: slamtry
Last Post: 883openpipes
0 the far west burbs of Chicago
Last Post: lugster
Last Post: BrokenIron
0 More of a reintroduction
Last Post: lugster
0 05 and 73
Last Post: TT60
0 Racing tem up with Hero moto corp
Last Post: retired
0 The White Bike is the Right Bike Thread.
0 Starter motor
Last Post: sleighcrane
0 Found my bike on Google maps
Last Post: gravydog
5 Am I looking for Trouble ?
Last Post: Crosshairs
0 WTF Happened
Old 21st March 2012
Rickyrocket Rickyrocket is offline
Rickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the roughRickyrocket is a jewel in the rough
Default 03 ignition module removal
Ive got it down to where its loose on the plate,how do I UNPLUG w/o damaging it ,wires have no play
Old 21st March 2012
tich's Avatar
tich tich is offline
Sportster/Buell Model: 883r -1200
Other Motorcycle Model: 850 Yamaha TRX
Other Motorcycle Year: 98
tich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond reputetich has a reputation beyond repute
The plug is on the bottom frame towards the back of the engine.
When seperated it has a wedge (green I think) pull the wedge out and your wires will be free and will thread through.
best to right down the position of each couler wire before pulling the wedge.
Now you have an answer I can only hope I got the question.
If not
Bump Bump
Old 21st March 2012
your saying the wires go thru the motor & out the bottom? Ive got 2 manuals and neither explain it
Old 21st March 2012
steelworker's Avatar
Other Motorcycle Year: 2016
As Tich advised, the Deutsch block connector is under the rear of the frame rail. Disconnecting that should give you enough play to pull the module free of the cam cover.
If you want to remove it, then make a note of which wire goes where on the connector, use needle nose pliers to remove the locking wedge, then carefully hold back (with a pin or other pointy object) the plastic clip that holds each crimped wire end in place, while gently pulling the wire toward the back of the connector. Once all the wires are free of their clips, you should be able to pull the seal, with all the wires, out the back of the connector.
To reinstall, push the seal and wires back into the connector (in the correct orientation), then push each wire in turn until you hear the retaining clip snick into place. Once they're all in, replace the central locking wedge.
Old 21st March 2012
Yes, they pass out of the bottom of the cam cover and underneath the engine.
edit: pics in post number 8 of this thread may explain.
Old 21st March 2012
you guys as usual are right THANKS
Old 21st March 2012
OK the H-D gods have shined on me,changed ign.module($275 later)my cicle is runnin good as new and its *70 and sunny out plus its a slow day at work and I Got it off
