Last Post: Martysf
0 Solar battery charging
Last Post: drumbrake
0 Iree's jukbox joint
Last Post: rubine
Last Post: Twistedrench
0 Cartridge Conversion?
0 Primary Oil INSANITY!
Last Post: GrimKvlt
Last Post: tvon
Last Post: tvon
Last Post: Wharfcreek
0 1979 oil routing diagram
Last Post: Jorgem79
0 Mid's or rear sets
  #391
Old 4th July 2012
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
I've been running the switches lately. I've been changing maps every evening. Going back to revisit the Rico maps.
"Only Fools Celebrate A Fool"
Old 4th July 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Have you got it to the point that it's hard to actually tell the difference between one set of switch settings or another? Or does each change have a definite difference?
[SIZE="2"][/SIZE]Support the forum because the :xlrocks
George
[COLOR="Blue"][B]"Peace is that brief glorious moment in history when everybody stands around reloading . "
--Thomas Jefferson[/B][/COLOR]
Old 4th July 2012
rocketmangb's Avatar
Scott
The "Nomad" is a Big Bore map when set to 5-5 as I understand it
Its a Stage I map at 8 initial switch
Rico wrote it while I was holding a 1911A1 to his head !
I dynoed it both ways and the Initial switch at 8 pulled my best ever
Rico might not agree but he argued with me about the Jester as well
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 4th July 2012
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
The "Nomad isn't a big bore map per say...it was never intended as a map for street use at all. It is an R&D map which was written for rocketdude. He asked for a map that he could safely add or subtract 5 degrees of advance while on the dyno with his Stage 1.
I'll send it to anyone who wants it, but again...it wasn't written to improve performance.
Sic Semper Evello Mortem Tyrannis
Old 4th July 2012
Rico 05R's Avatar
JESTER SYNDICATE
Scott, I've sent it to your email. I still have it in my map library as R&D map, I didn't save it with the Nomad name.
Old 4th July 2012
It seems to run just fine and it dont ping !
Old 5th July 2012
I've settled on 6.0 switch settings. It feels better than 5.0. The biggest difference I can tell is when I offset the rear cylinder. Keep in mind I'm also boosting the fuel. I've ran it as high as 98 octane but have got it down to 93 now. It doesn't seem to like 91 in this heat. Went on a 5 hour ride yesterday with a friend who rides a 1000 cc Vstrom. What a nice bike that is! My bike ran fine I just couldn't keep up with him in the turns. Of course I ride a lot more conservatively now since the wreck and that Vstrom rides and handles like a dream. That being said, my friend still out rode me when he was on my bike. I've been operating the bike in 80-100*+ temps. I'll probably quit boosting the fuel when the weather cools down. That brings up another point, the weather, the bike seems to like cooler moist air better than hot dry air. There are to many variables to make a definitive observation when the only tool I'm using to help decide what changes if any I need to make is my ass. I've got over 3,000 miles on the build now and it's still ticking and when it's hot, it really ticks. When it's cold, it sounds fine.
Old 5th July 2012
Rico 05R's Avatar
JESTER SYNDICATE
How far have you offset the rear cylinder Scott, and can you describe your impressions?
Old 5th July 2012
All I've done is retard the rear cylinder 1*. It didn't seem to idle or run as smooth as when not offset. It sounded more like a 2 into 2 bike. Offsetting the rear cylinder didn't seem to offer any performance gain that I could tell. A dyno test may tell a different tale.
Old 5th July 2012
Lenster's Avatar
Lenster Lenster is offline
Lenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond reputeLenster has a reputation beyond repute
Hey Scott, have you tried the King Jester? That's what I'm running and I like it a lot.
Now if I could just get time to get me jetting down and then on the dyno
Lenster's 1250 2006 XL1250C, Hammer Crush Heads, 15 Degree Pistons, 10.5:1 CR, S&S Roller Rockers, Fixed Length Pushrods, Jim's Powerglide II Hydraulic Lifters, RedShift 585 Cams, Energy 1 Clutch w/ 15% Stronger Spring, Hammer Performance Billet Intake Manifold, Mikuni HSR 45 (25 Pilot, 157.5 Main, 96 Needle 2nd Clip from top, Y6 Needle Jet), Offset Crush AC, Cobra Power Pro HP 2:1 Exhaust and a Daytona Twin Tec TC88A with a Kickass Map by Rico 05R.
