0 Paulie420 needs your help.
Last Post: Jowniofownio
0 Not charging issue!
0 Value of a Boattail?
Last Post: Moon Wolf
Last Post: yoshi
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 1977 Bright Blue
Last Post: Airarbiter
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
Last Post: RandyMac
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
back rest, bar, sissy
Old 24th March 2012
Batousaii's Avatar
Batousaii Batousaii is offline
Sportster/Buell Model: XLCH Ironhead
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XL 883 Evo
Sportster/Buell Year #2: 1994
Batousaii is an unknown quantity at this point
Default Home Made Sissy Bar / Back Rest? ~ Ideas?
Thinking of building a sissy bar with back rest.
- Looking for ideas and suggestions on materials, bending, structure, strength etc.
- I want it to be functional, to lean against, and to strap a back-pack to.
some do's and dont's appreciated.
creative approach welcome!
outside the box - cool.
Inexpensive - absolutely.
- I'm asking in the ironhead section, cause i know you guys have tons of experience doin things old-school style The idea may be used on both my iron and my evo.
Thanks again guys
Bat
1969 XLCH 900cc Mild Performance Ironhead & 1994 XL 883cc Comfortable Evolution.
Old 25th March 2012
jred jred is offline
Other Motorcycle Model: gl1100 & xs650
Other Motorcycle Year: 1980
jred is an unknown quantity at this point
If it were me, I'd use some 1 1/2" x 1/4" steel for the brackets, drill mounting holes. 1"x1/4" steel for the upright, bend the upright around a small tree , weld to the brackets, rattlecan the whole shebang.
If you want to get fancy, use square stock for the upright & twist it.
I'm not a real mechanic, but I play one in my garage.
Old 25th March 2012
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
I have a small sissy bar that came w/ a project.
It mounts to early sportsters rear fender rails.
It is square tube, chrome is flaking.
I will sell cheap and you could easily build off of it.
Let me know if your interested.
Old 25th March 2012
CaptCaveman's Avatar
CaptCaveman CaptCaveman is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Various
CaptCaveman is an unknown quantity at this point
I've made a few over the the years using 1/2" or 5/8" square or round stock, sometimes a bit of 1/8" plate and a torch plus a bench vise.
First figure out how your going to mount it. Harley's are pretty easy because you can use saddle bag mounts or drill and tap the fender brace though the first one I made for a 74 Honda 750 I used worm drive hose clamps to attach it to the frame under the seat.
If you want to add scroll work etc you can use a bender like this one, http://www.harborfreight.com/compact-bender-38470.html though I've done the same thing with a vise and a bit of creativity. Look through the biker catalogs. you can pretty much make a variation on almost anything they sell.
Still crazy after all these years
Old 27th March 2012
Batousaii's Avatar
I started the project today. Using some angle iron for the frame, a piece of plywood for the back of the cushion (my wife sews) and some aluminum bar for the sissy bar part. It's all very "home fab" custom ~ But looks good too. I'll post some picks when i get done.
- So far... $35 bucks
Old 28th March 2012
Stenrick Stenrick is offline
Sportster/Buell Year: 1984
Stenrick is an unknown quantity at this point
I just fired up the wire welder and turned @4 foot length of chain into a 1.5 foot tall sissy bar. Welded a 1" piece of strap between the sides at the top, and then used angle and channel iron to make new sideplates (wanted to move my signals to the back bolt so there was more room for my saddle bags).
I wasn't quite happy with how the sideplates turned out though, so I'm already thinking of a new version of those. Might have to actually draw them up, with dimensions, for future use if they turn out decent.
Old 28th March 2012
the cowboy way's Avatar
the cowboy way the cowboy way is offline
Sportster/Buell Model: hand built M/XL ironhead
Sportster/Buell Year: 9293
Sportster/Buell Model #2: 1976 motor in a 1987 fram
Sportster/Buell Year #2: ????
Other Motorcycle Model: 1974 XL & 2003 FXD
Other Motorcycle Year: 7403
the cowboy way has disabled reputation
stainless
If I were makin 1 it would be made out of stainless
Forever Two Wheels
1997 AMRA National E-class Champion
Ironhead parts I have tons of em
machine shop @ home
Old 28th March 2012
nativebroncofan's Avatar
nativebroncofan nativebroncofan is offline
Sportster/Buell Model: XL 1000
Sportster/Buell Year: 1979
Sportster/Buell Model #2: xl1200x
Sportster/Buell Year #2: 2016
nativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to allnativebroncofan is a name known to all
What I have done is to take a piece of ornamental iron for a window covering and basically bent it around a stock sissy bar and welded three pieces of hexagonal stock as back rest holders. I drilled holes in the octo stock to receive the bolts for the back rest and the changeable back plate. Now mind you it ain't much(the cushion), but then again no one has ever really been a passenger on the back of my bike. I will try and get a pic and post it later today in the mean time here's the back side of it from a thread that I started in August of 09 ----- follow hyper link------http://xlforum.net/forums/s...d.php?t=572457
:gun [FONT="Impact"]FOR WHOM THE BELL TOLLS[/FONT] :gun
Old 28th March 2012
Here is the pic that I mentioned. NBF
Old 29th March 2012
hugie03flhr hugie03flhr is offline
Sportster/Buell Model: Buell M2
hugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enough
A freind of mine used an ornamental gate spike.from a cemetery !!!
