0 2016 48 Hesitating
Last Post: 201648Rider
Last Post: Jheitt
0 New member in MD
Last Post: Veeflys
0 Primary Oil INSANITY!
0 Newbie CV rebuild
Last Post: Matt Black
0 Ei
Last Post: cazz1000
0 Decman's Birtday
0 Turn signals
Last Post: bockstroker
Last Post: r4fthrs
0 Oil??
  #61
Old 30th March 2012
timberjack's Avatar
timberjack timberjack is offline
Sportster/Buell Year #2: 1973
Other Motorcycle Model: 2002 sporty heavy modded
timberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura abouttimberjack has a spectacular aura about
ok after awhile i found one i could get a measurement on the rocker arm bushings and it was .556 for all of them and the rocker shaft is .5535 , so its a nice snug fit.I not sure if the book has specs for this or not i will have to look.I am so certian that the very poor job done on my heads ( i prob couldnt keep up to the fluid leaking out of valve on the first poor seat i fixed) (the last one that i got pic of leaking was the gd one) was the miss problem, but time will soon tell.
Checked it out and .0025 is max (am i readin this right? its a dam clymer). So remeasured, I may have been pressing a lil hard on the bushings and this time I get .555 regardless if i am reading this right I will have to replace these bushings and might just aswell get rocker arm shafts aswell.I hope you tell me i am reading this wrong.
Old 30th March 2012
wedge's Avatar
wedge wedge is offline
I sure wouldn't mess with that. The worst loose rockers will do is make a little noise. Better a little loose than a little tight.
Old 30th March 2012
timberjack's Avatar
Thanks Wedge, I was kinda wondering got to be the dam clymer!! ok they go back together then.
been cleaning in the garage man i let it get messy this time , just gettin a nice spot for the parts to sit and a spot for the motor to set on.just have to remove the primary cover and lift it out.Hittin town for a fred kodlin WG triple tree's i purchased for another project.when i come home i will clean and check the oil pump for wear i might aswell just picture this ordeal as i go to, it may help others someday.
Old 30th March 2012
brucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud of
according to your measurements,you are within spec. you have 1-1/2,thousandths clearance,your allowed 2-1/2,thousandths,clearance.i,deleted the decimal points and zeros to make it easier to understand.
Old 31st March 2012
wedge's Avatar
Good catch, I didn't notice the second reading of .555
Old 31st March 2012
thanks,but even the extra .001,would have put right at the limit.
Old 31st March 2012
timberjack's Avatar
Yes my first measurement was on the line the second is .005 room for more wear thats not much can someone check there hd manual and see what the max celarance is on these ?is the clymer wrong or is it really .0025?
Old 31st March 2012
my 1957-69 h-d fsm,says .0005-.002. fit in bushing.the newer manual probably gives the extra 1/2,thousandth clymer is stating.rocker arm shafts changed in 1971. [your still within specs.] .0025,is 2-1/2,thousandths.in simple terms.
Old 31st March 2012
timberjack's Avatar
ok, i will live with it for now..sorry for delay was cleaning and found some beer thought it may go bad so i cleaned it up to..back shortly with oil pump findings.
Actually i was bieng a detective and workin on a case LOL!!!
Well with certain trouble to be uncovered soon here is a pic of whats to come.
Will i get that s&s? hmm will i use y grinds? soon see...
Old 31st March 2012
timberjack's Avatar
oh boy!!! lol.
I will start to split stuff after i go to town for more brak kleen and BEER i am gonna have some sorrows to drown...lol
