0 What's your helmet?
Last Post: Jheitt
Last Post: hscic
Last Post: Hellbent_4
Last Post: MCCoy
0 The Welsh Way, 21st April 2018
0 Show your tank decals
Last Post: kap
0 Tuning
Last Post: XLXR
0 Spokes or Mags
0 New in NM
Last Post: spoon
883 mods, stage 1
Old 29th March 2012
NRsportster's Avatar
NRsportster NRsportster is offline
Sportster/Buell Model: XL 883
NRsportster is an unknown quantity at this point
Default Advice on sreaming eagle AC
Thinking of doing stage 1 (SE) upgrade on my 883. Many questions: Will it be worth it on 883 or is it more for 1200s? I could maybe change the AC but would not attempt to mess with the carb. What would be cost of paying a shop to do the work? If i ever do 1200 conversion will these improvement still apply or require other AC or exaust? Can AC and carb jetted be done and wait til later to upgrade axaust or must the whole stage 1 be done at once? Answer what you can people. Many questions but just thinking ahead and trying not to waste money by doing things out of sequence. Thanks
Old 29th March 2012
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Anytime you allow a motor to breathe better, it's good for the motor. Will you notice a significant difference in the performance.......not likely. Now if you do intake and exhaust.....you should see/feel a difference. As far as changing the breather only............I can't fathom a shop charging more than an hour labor to change and adjust carb. Realistically.....30 minutes might be more like it!
I don't know what an S/E breather goes for these days, but you should consider one from NRHS or Hammer Performance if they are similarly or closely priced. Superior unit's for sure. They also come with a K&N element that can be cleaned and re-used.
It's not mandatory to do both intake and exhaust at the same time, and any changes you make now, will still be applicable for a 1200 if you upgrade the motor later.
As far as changing the breather only, then adjusting the carb.......you can do that yourself with a couple basic tools!
Stuff: YES
