Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
Old 15th April 2012
SoFLJoe's Avatar
SoFLJoe SoFLJoe is offline
Sportster/Buell Model: 883
Sportster/Buell Year: 86
SoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the roughSoFLJoe is a jewel in the rough
Default oil hose kink?
I changed the oil on my 86 sportster today and when I was looking at the oil line from the bottom of the oil tank, it appears kinked. I played with the hose some, and from the service manual it appears to be routed correctly. Maybe its just the way it bends, but I was wondering if someone might have a closeup pic of this. I have attached how mine looks.
EDIT: After pulling the two hoses off the oil pump and seeing a slow steady drip like when the oil is almost done draining from one hose and a few second drain on the other hose then that hose stopped, I am going to play it safe and replace the hose from the oil tank to the oil pump. Does anyone know the size of the hose so I can pick one up before I remove the old hose? Thanks!
Old 18th April 2012
urshurak776's Avatar
urshurak776 urshurak776 is offline
Sportster/Buell Model: XL 1200R
urshurak776 is an unknown quantity at this point
If your replacing it just take it to an auto parts store or a dealer/Indy. Just make sure the new hose is certified for oil applications.
Old 18th April 2012
thatbikerguy's Avatar
thatbikerguy thatbikerguy is offline
Other Motorcycle Model: Suzuki GS 750 L
Other Motorcycle Year: 81
thatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud ofthatbikerguy has much to be proud of
Looks like an elbow. Not kinked, made that way...
expect the unexpected
2003 1200 XLC Sterling Silver/ Vivid Black
Old 18th April 2012
kd460's Avatar
kd460 kd460 is offline
Sportster/Buell Model: XLH883
Sportster/Buell Year: 1987
kd460 has disabled reputation
It's not an elbow. It is a kink. It uses 3/8ths hose. Pick up 3 feet of good quality hose that can handle oil and temperature. 3 feet will give you a little extra.
Looking at my 87, if you mean "feed" being the hose nipple on the bottom of the oil tank, that hose goes from the oil tank nipple (the one on the very bottom), and routes UNDER the starter.
It then makes a soft bend down towards the ground in the area between the starter and the rear cylinder exhaust pushrod tube, (also that is the area where the seam is for the sprocket cover and the cam cover where they meet). The hose can be slipped behind these covers (at the junction of the two covers) without removing the covers.
The hose then drops down to follow along the frame (look from underneath the bike) and over to the oil pump.
If you feed the hose starting at the oil pump, and then going along the frame tube, then up to the starter at the area described (behind the covers mentioned earlier), you should be able to feed that hose under the starter to the oil tank without having to remove the starter or any covers..
Hope that description helps. It was a mouth full. KD
Old 18th April 2012
SoFLJoe's Avatar
KD460, Thank you, that explains it pretty much perfectly.
Old 18th April 2012
kd460's Avatar
Good deal, glad to help
Old 19th April 2012
SoFLJoe's Avatar
Got the hose replaced today. Only took about 45 minutes, most of the time was spent making sure the new hose wasn't kinked. Thanks again for the info.
Old 19th April 2012
kd460's Avatar
Ride on!
