Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
Old 25th April 2012
theymademdoit's Avatar
theymademdoit theymademdoit is offline
Sportster/Buell Model: Sportster 883c
theymademdoit is an unknown quantity at this point
Default Replace 883 jugs with stocks 1200 jugs
I have 2007 883c and have a chance to buy a set of stock 1200 jugs and pistons. Can I just replace the jugs and pistons with the 1200 hundred jugs with little or no other modifications?
Old 25th April 2012
darkdesign's Avatar
darkdesign darkdesign is offline
Sportster/Buell Model: xl883c
darkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to behold
i'm pretty sure that's ok, so long as you have new gaskets etc. Have a look at 1200 upgrade kits to see what you're missing. The big question is, why has someone taken off their 1200 jugs if there's nothing wrong with them?
Old 25th April 2012
td67mustang's Avatar
td67mustang td67mustang is offline
td67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura about
perhaps to upgrade to a 1250 kit like all the rage among this forum lately..
Old 25th April 2012
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
You can use the jugs, but not the pistons. With your 883 heads the stock 1200 pistons will have far too high a compression ratio. You need dished 'conversion' pistons. The dished tops of the pistons, in effect, increase the volume of the combustion chamber compared to the swept volume.
Folkie
South East England Riders
Old 25th April 2012
proturn's Avatar
proturn proturn is offline
Sportster/Buell Model: 883c/1203xb
Sportster/Buell Model #2: 1994 XL1200
Other Motorcycle Model: 1998 Heritage ST
proturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to behold
Thumbs up
The jugs will work from 1988 and up with no issues. Most of the time all you will need to do break the glaze with a hone so the rings will seal. I would recomend that you replace the rings with new ones just to be safe. The ring sets are about $18 bucks each from harley. You will need 2 sets
Most shops will charge $20 -40 for honing and have that machine shop pocket the top of the pistons .100"deep x 2.75" diameter $40-60, $30-40 for a top end gasket kit (James or V-twin) So for around $200 and whatever you have to pay for the cylinders and pistons, you will have a 1200!
Good luck!
Proturn
Old 25th April 2012
Folkie's Avatar
Brass Nut
Ideally you should change the ignition and put in a stronger clutch spring.
Old 25th April 2012
ReddTigger's Avatar
Or....
You can scour the internet for a set of inexpensive 1200 heads, to bolt on.. Typically they can be found now and again for the $300-$500 mark (depending on your budget)
States I've Ridden in
71.3 hp 70.8 tq
Old 25th April 2012
Thanks for all the replies.
So I would have to replace the pistons?
Ok so say I get the jugs and pistons for 325 about how much more would everything I need cost. Would an 1250 kit be more cost effective?
Old 25th April 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
All depends on your ultimate goal. How much more are you going to want down the road? Only you know that.
George
--Thomas Jefferson
Old 25th April 2012
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
You could get a little head work done to increase their displacement and keep the pistons as is. The forum has two excellent hot rodding vendors for this stuff.
