Last Post: Vohnsen
0 Fact or Fiction - HP Claims
0 More of a reintroduction
Last Post: spitfirechopper
0 Cylinder Piston kits
0 Clutch Spring plate poll
Last Post: NZstu
0 Trade Chrome for Black?
0 Bars on C Riser?
0 1967 XLCH stroker project
Last Post: kaveebee
0 crack in head
Last Post: slamtry
Last Post: 45Brit
Last Post: kaveebee
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
Old 4th May 2012
memikeni's Avatar
memikeni memikeni is offline
Sportster/Buell Model: Sportster Forty Eight
memikeni is just really nicememikeni is just really nicememikeni is just really nicememikeni is just really nicememikeni is just really nicememikeni is just really nicememikeni is just really nicememikeni is just really nicememikeni is just really nicememikeni is just really nicememikeni is just really nice
Default 4.5 gallon tank swap on 2011 Sportster 48
any advice from someone who has done this particular swap? From what I understand it's just a straight swap........my tank arrives later today....
Last edited by Folkie; 10th May 2012 at 22:14.. Reason: Improved layout to reduce width
Old 4th May 2012
FiremanTx's Avatar
FiremanTx FiremanTx is offline
FiremanTx is an unknown quantity at this point
this might help
http://xlforum.net/forums/s....php?t=1415916
Old 4th May 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
Originally Posted by FiremanTx View Post
+1 - that should be all you need. Switch fuel pump and lines to new tank and remount.
Old 4th May 2012
Sporting Lad's Avatar
Sporting Lad Sporting Lad is offline
Sporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud of
Arrow A few tips...
I swapped the 3.3g on my '06 for the 4.5g.
It was an easy bolt on.
I had to modify my OEM seat cos the 4.5 is longer, but you may be OK what with that gap already there.
Here are a few DIY tips re the swap procedure (some of the technical details may be different on your '11; read your Service Manual):
a) Empty the peanut before you remove it! Many XL owners have had a tank with gas sloshing around in it tumble out of their grasp and hit the shop floor like a hard-boiled egg
b) Mind the hoses attached to the underside of the tank:
> the fuel line emerging from the petcock
> the vent (overflow) hose
> the nasty vapors hose
c) You'll prolly move your old petcock to the new tank. Take advantage of this opportunity to clean the filter before re-installing petcock.
d) Your new tank will ride lower than your peanut, so accessing wiring and hoses underneath the tank will be more difficult.
e) Take your time installing the 4.5. Those 'ears' holding the front in place can be a bit of a hassle. Patience. You may have to try several times before it goes on correctly.
f) Remember to reconnect all those hoses! Count them to be sure. If you overlook the vapor hose your engine will run crappy.
g) CHECK FOR LEAKS! Any hint of gas escaping? You don't want that.
When you restart, listen for air leaks. Remember to open the petcock valve. Oh, and remember to put some gas in the tank. Don't laugh--people have done this, then start thinking their ignition needs work.
h) What plans do you have for that tiny old tank?
[SIGPIC][/SIGPIC]'06 XL 883/1200, [B][I]"BLACK MARIAH":[/I][/B]
Wiseco K1655s; Joker Machine AC; SE 'SP' muffs w/ Cycle Shack baffles; OEM SHOCKS on Tamarack -1" blocks; Metz 880s (110x19; 160x15) on laced wheels; Progressive fork springs; 4.5 gal tank; ReddTigger Mod Gauge Mount System...
See thread [url]http://xlforum.net/forums/showthread.php?t=1102057[/url] for a "[I]pictorial history[/I]".
Old 5th May 2012
lostNdallas's Avatar
lostNdallas lostNdallas is offline
lostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond reputelostNdallas has a reputation beyond repute
The stock 48 seat is designed for the 4.5 gal tank spacing. If your seat is not designed for the 4.5 gal tank, you may not have enough room in there. The vent hose on the 2.1 connects in a different spot than the 3.3 or the 4.5 so it may require a bit of cutting to work right.
Nothing against the previous post but a lot of that doesn't apply to EFI. There is no vapor hose nor is there a petcock. There is a push-to-connect style fuel quick disconnection joint and there is an electrical plug for the fuel sending unit. I haven't watched the video by screw loose dan but I would be willing to bet that it is all covered. Also, the tunnel in my 2.1 is much deeper than on my 3.3 so the larger capacity tank actually sits higher on the spine. Never mocked up a 4.5 on it though so I can't compare that.
Some people (like the OEM) recommend always replacing the fuel sending unit gasket. I didn't and it works fine so far.
Once you get everything bolted back on, slowly and carefully move the handlebars from lock to lock and make sure you're not hitting the tank with the mirrors.
That's all I can think of for now.
The journey IS the destination. (L-1,C-1,R-3)
Old 5th May 2012
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
If you didn't already swap the tanks over, it should be fairly straight forward. Only two things I can think of might be the vent hose mentioned by lostNdallas and the seat if you don't have the original. Off the top of my head, I believe the fuel line for the larger tanks is actually a different part number, but I know plenty of folks have swapped tanks without any issue using their original fuel line.
FYI, below are pictures are what the tank looks like with the fuel pump removed and a separate picture of the fuel pump.
(that green bit around the bottom is the gasket lostNdallas mentions.)
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Last edited by Screw Loose Dan; 21st February 2018 at 19:29.. Reason: Updating link to pictures
Old 5th May 2012
memikeni's Avatar
Default swap has been done......
thanks for all the advice.........
Old 5th May 2012
FiremanTx's Avatar
looks sharp, came out nice!
Old 5th May 2012
Nice. It's amazing how a tank can completely change the look. I guess I was worrying about mirror strikes for nothing.
Old 5th May 2012
memikeni's Avatar
