Last Post: toe
24th February 2010
Posts: 6,809 Sportster/Buell Model: 883/1200C Sportster/Buell Year: 2000 Other Motorcycle Model: Harley Heritage Other Motorcycle Year: 2007
The heads breather bolts allow for the engine crankcase pressure to be vented. HD uses hollow bolts into the air cleaner and the oily mist is sucked into the engine via the carb/TB and burnt. You must vent the heads or your crankcase will build pressure and cause gasket failures not to mention the loss in power...they are NEEDED.
Some air cleaners are not set up to allow for the breather bolts into them and are only held on by the three small carb front bolts. For these breathers you would need to get a head breather kit and carb support bracket. The breather kit routes the head vents to the ground while the carb support bracket keeps the carb in the intake.
I think the S&S requires the use of the breather kit but has the carb support feature built into the backing plate.
Search through the Drag Specialites fatbook for carb support bracket and head breather kit and you should be able to understand better how they work.
Shu
GONE BUT NEVER FORGOTTEN
Screamin' Eagle 10:1 pistons
Stage 2 883 heads
Screamin' Eagle .497" cams
Screamin' Eagle Mikuni HSR42
Thunderheader
Forcewinder
24th February 2010
Posts: 1,182 Sportster/Buell Model: XL 883C Sportster/Buell Year: 2007
Does this apply to EFI bike as well? The reason I ask is because I have read and been told that when installing the S&S Tear Drop AC on an EFI Bike, you eliminate the carb support.
'07 Vivid Black 883C - Mustang Vintage Solo and pillion, some Willie G and some other chrome shtuff, X2 grips, Lick's Black Solo Bag, K&N kit, Cobra Speedster Slashdown pipes and remap. . .More to come...SHWEEET!!!
24th February 2010
I think the EFI throttle body would still need a support bracket of some whether built into the carb backing plate or a separate part. When you look at your TB, air cleaner and how the TB is attached to the intake manifold, what does it look like? Picture?
24th February 2010
Posts: 444 Sportster/Buell Model: 1200N Sportster/Buell Year: 2009
Originally Posted by drvsafe
Can I ask an absolute Newbie question?
What IS a breather bolt's purpose? I mean I have an '07 883C, with a standard ham can AC and a K&N Drop in filter. I am looking to swap it out to an S&S Tear Drop AC this spring. Neither set up is ever seen with those breather bolts, so I know they are not NEEDED. But what purpose do they serve? I've searched the internet for even a definition and have not been able to find one. I know that I can ask this question HERE and not be looked down upon for asking it...
So, hit me....breather bolt....Let's take our first call..
To illustrate on what Shu Posted:
Here is your ham can without the filter. The center gold looking thing is your intake. The two bolts on either side of it are your breather bolts that go into the heads of your motor and let the oily stuff come out. With the stock configuration this stuff is vented right back into your intake. Bad juju.
Here is a pic of the stock breather bolts on the right, and the after market ones on the left. (Drag Specialties kit) As you can see the holes are much bigger and allow more gunk to get out of the motor. Which is a good thing.
Here is a pic of the heads and intake with nothing on them at all. Just to show you what it looks like. There are 3 holes here that you can see one on either head is where the breather bolts go, and one in the center above the intake for the bracket to hold everything together.
Here is a pic of whats needed for 07 and up. Bracket on the far right (Stock Bracket that came on the bike), Breather bolts, banjo things (I forget the correct term but they go on the breather bolt to give you a place to put a hose) and some thread lock and some gasket maker. (the gasket maker isn't really needed I just used it for piece of mind inbetween the bracket and the heads) and Fiber washers to go on either side of the banjo type things.
here it is assembled. Bracket on top, with breather bolts installed waiting for the line to be attached.
Here is a pic of the completed assembly. breather is hanging underneath the intake.
Picture of the finished product.
All said and done you can't see any of the breather parts behind the new mounting plate... just the way I like it. This set up is on my 09 so it will be the same as your 07. Just imagine a tear drop backplate on there instead of my NRHS Hurricane one.
24th February 2010
Holy shamolies, that is the most concise, plain English definition of this area of the bike I have ever seen. The pictures explain it perfectly. I have about as COMPLETE an understanding of this area now as I ever will without actually striping the parts down and getting dirty. thanks much. What kills me is that my bike is in storage and I can't get to this until spring thaw.
So from what I gather, I will purchase the kit from S&S, it will come with everything I need, I notice that I will be using the stock breather as from what I see, the S&S kit doesn't come with it as demonstrated here...correct?
24th February 2010
Senior Bike Builder
Posts: 1,917 Sportster/Buell Model: XL883L Superlow Sportster/Buell Year: 2011 Sportster/Buell Model #2: FLHTKL Limited Low Sportster/Buell Year #2: 2015 Other Motorcycle Model: FLSTN Softail Deluxe Other Motorcycle Year: 2011
I can't understand why anyone would want that breather in a position where it would drip onto the engine. I routed mine just above the intake, so any oil drip blowing would eventually find its way back to where it belongs...
Reason: additional closeup
24th February 2010
Brass Nut
Posts: 46,951 Sportster/Buell Model: XL1200CB Sportster/Buell Year: 2015 Other Motorcycle Model: CRF250L Other Motorcycle Year: 2017
Yes they are, the stock a/c is fixed to the heads with breather bolts. As is the S&S, or its brackets are, anyway. The breather bolts purpose is to route the breather gasses to wherever you want them to go, and also supports the a/c, either directly, as with the stock a/c, or using a bracket or brackets.
Folkie
South East England Riders
24th February 2010
I agree that is the best pictorial i could imagine on this topic. Thank you. WOW I never knew the new bikes stock breather bolts were that small in diameter for breathing.!!! Holy crap that is restrictive. When it is idling how much pressure is coming out of those?
That S&S kit that you reference is complete with banjo's and bolts etc and carb support brackets. You will not need to use any of the stock parts.
24th February 2010
Brass Nut
If by 'where it belongs', you mean: back in the motor, then that won't happen, as the oil would have to go uphill to get back in the rockers, and there are umbrella valves there which are specifically designed to stop anything getting back in. All you are doing is blocking your breather lines with oil.
24th February 2010
does anyone have photos detailing the installation of the S&S tear drop AC on an EFI Sporty? I know I am asking for specifics here, but hey you never know.
