Last Post: hhugger
0 Slip on muffler
Last Post: Tucsonmax1
0 1972 tank fitment
0 bike went for a slide
0 New England 2018
Last Post: The Crusher
0 90 in. Build
Last Post: Jheitt
0 Help me with gas cap...
0 Sportster or Street Bob
0 2016 48 Hesitating
Last Post: Screw Loose Dan
Last Post: dnaj11
Old 7th May 2012
MONTY MONTY is offline
Sportster/Buell Year: 1991
Other Motorcycle Model: FL1200
Other Motorcycle Year: 1960
MONTY is an unknown quantity at this point
Default CV carb - spitting fuel back?
Ok, i never messed with an Evo CV before but since i got them working on Big Twins OK, what's the diff, right?
So i finally get round to "staging" my old '91 XL hack bike by swapping the stock air cleaner for a SE ham-can arrangement with a K&N filter in it and flat back-plate (like the old days, LOL).
I asked a mate for jetting suggestions and he said 48/185 which sounded a little thick (i have a Evo BT with the same jets, but a whole lot more cubes!), but he's more experienced than me so i went with it.
SO: bike runs fine, starts so easy and comes off the enricher a bit too quick, suggesting it's a bit rich. But what i don't understand is the puddle of fuel that keeps forming under the carb, inbetween the tappet blocks! First i thought i'd forgotten to tighten the hose clamp on the fuel line, but no - when i was checking that i could see the fuel was coming out of the carb itself, via the air cleaner. But, i thinks, if it were flooding (maybe got some shit in the float bowl and float valve isn't shutting properly) then fuel would come out of the overflow tube as well, and if i left the fuel on it would run out on the floor ... but it doesn't.
The bike does pop a little though the mufflers on overrun (but actually less than it used to), but i haven't heard it spit back in the carb, so where the hell is the fuel coming from, and how do i stop it? Is it the jetting, or have i screwed up something else?
Any help/suggestions appreciated!!
Cheers
p.s. i re-directed the breather away from the air cleaner - dunno what diff that would make but thought i'd mention it anyway!
MONTY
Work to ride, ride to work!
Old 7th May 2012
LuxBlue's Avatar
LuxBlue LuxBlue is offline
883? Try jetting at 42/165 or maybe 45/170. As far as the puddle...most likely crap in the needle valve or your accelerator pump diaphram is leaking.
Old 7th May 2012
nmbillb's Avatar
nmbillb nmbillb is offline
Sportster/Buell Model: XL883C
Other Motorcycle Year: 1996
nmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud ofnmbillb has much to be proud of
I have the same problem...here's a vid I made a couple of years ago...fuel blows back out of the carb on accel. Probably jetted too rich.
Bill in Southern New Mexico - '99 XL883c
I miss Mr. Jimi!
RIP BryanEOD
When I carry a gun, I don’t do so because I’m looking for a fight, but
because I’m looking to be left alone. - Marko Kloos
XLF Road Help [URL]http://xlforum.net/forums/showthread.php?t=670716[/URL]
My recent accident [URL]http://xlforum.net/forums/showthread.php?p=4397043#poststop[/URL]
Old 8th May 2012
CharlieB's Avatar
CharlieB CharlieB is offline
Sportster/Buell Model #2: XLH 883 Deluxe - sold now
Sportster/Buell Year #2: 1986
Other Motorcycle Model: FXDWGi
CharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really nice
Too rich? Reversion is more likely. What exhaust?
Old 8th May 2012
Thanks for the replies guys.
Yes it's an 883, pipes are stock headers (with balance pipe under carb - doh!) and stock mufflers "messed up a bit". I've pretty much convinced myself it's not the needle valve as i can leave it standing with the fuel on and nothing happens, but the accel pump diaphragm sound possible, though i didn't mess with it at all so not sure why it would suddenly start leaking so bad ...
Lux, that jetting sounds pretty lean, in fact i think the first option you suggest (42/165) is leaner than the factory jets i took out! I'd have to check in the workshop when i get home (at work right now) but i think it was 42/170 (UK spec., as that's where i am).
Bill, that's an interesting video!! I can't for the life of me understand how opening the throttle makes fuel spray outwards that way, but if that's what's happening on mine then it would explain everything. I never thought to try running it with the filter off, but that's the first thing i'm gonna do tonight!
Thanks again
Old 8th May 2012
LuxBlue's Avatar
My 1200 with taxes paid...V&H short shots and Hurricane air filter is running 45/180. Your 883 doesn't need that much fuel.
Old 8th May 2012
beuz's Avatar
beuz beuz is offline
Sportster/Buell Model: SPORTSTER "old boy"
Sportster/Buell Model #2: SPORTSTER CR (sold)
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Suzuki GSF 650 Bandit
beuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond repute
175/42 with between 2.1/4 and 2.1/2 turns is perfect for a 883 carb.
You live more in 5 minutes flat out on a bike like this than most people do in a lifetime...
Burt Munro.
Old 8th May 2012
Yeah, it's certainly looking that way! Like i said though, i'm pretty sure it was a 42/170 combo i took out (need to check) so maybe i'll try something like 45/175.
Old 8th May 2012
wedge's Avatar
wedge wedge is offline
This is not how you determine jetting. It's much more of an exact science. You need to learn how to read plugs accurately (try reading "plug reading 101" in the sticky's), then you need to jet accordingly. There is a CV 101 in the sticky's (or a name similar to that) that will help you tune the carb once you know what the plugs are telling you.
First off, the main jet can be a 175 to start with because as long as it's more than you need you will be fine until you get to WOT, and that doesn't happen all that often in daily riding. You could throw the main jet away and the bike would run the same until you got to around 3/4 throttle.
The 42 pilot may be just fine, but if the plugs and the "feel" of the bike is asking for the 45 then you can tune to that pilot, but a 48 is way too big.
I would start with 42/175 and then read plugs, take some test runs, read plugs again, and tune it from there.
What you never want to do is just throw in jets that some dyno jockey says are right, because every engine and pipe/air cleaner combination is different.
I also think you need to open up that exhaust, because without doing that, your performance over stock will be almost the same as stock. Which means that you probably didn't need to alter the carb at all.
Oh, look back at Beuz's post. He suggested the 42/175 also. Sounds like a good starting point to me.
Old 8th May 2012
OK, did a quick look at running with filter off, blip the throttle but none of that spraying back in Bill's video, so at least that's a relief. Too damn tired to mess much else tonight, but i did check the jets i took out - my memory was wrong, they were 45/175!! So i checked in the Clymer manual, and sure enough, just for that one year (1991), all non-California 883s got 45/175 as stock.
I already checked the plugs couple days ago (yea i can read plugs, been riding and wrenching my own bikes 30+ years) after a coupla days riding on new set up, and actually they look OK, certainly no sign of being overly rich, not sooty or anything like that.
Wonder about even putting back the stock jets and seeing if that's not too lean but actually might be OK ...!
