0 THE Trainspotting Thread
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
0 Paulie420 needs your help.
Last Post: The Crusher
Last Post: RandyMac
0 Not charging issue!
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 1977 Bright Blue
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
0 2001 883 'customizing' log
Last Post: Jheitt
Old 9th May 2012
do0zman do0zman is offline
Sportster/Buell Model: Sportster 1200c
do0zman is an unknown quantity at this point
Default Do0zman's XB12 Conversion.
I received all the parts I was waiting on and started the conversion yesterday The bike starts as a 2000 1200c will be putting in a stock Buell XB12 top end. Here is the list of parts that i picked up.
XB12 top end (pistons, jugs and heads)
Andrews N4 cams
Fix length pushrods .040 shorter (Thanks NRHS)
Cometic .030 full top end gasket kit
New Rings
Bassani road rage 2-1 exhaust.
Jagg slim oil cooler
Jagg oil cooler adapter kit.
Rubber mount to solid mount Engine mount(not the one in the photo)
The process started very slow I had to remove the old gaskets from the jugs and heads took a few hours for this to actually happen I scarred a few parts on the base of the cylinders so i hope it doesn't cause problems sealing.
Here is what i started with
Here it is with one cylinder done and the other almost there
After i got everything prepped time to start on the bike.
Nice little reminder so when i get in the moment of first start i wont forget... Seen this happen a few times to a few people.
Here she is w/ everything out of the way
Top rockerbox cover off.
Lower rockerboxes off
Rear head off
both heads off
Jugs off
Goodbye pistons.
That's all I've done up till now. This is my first bike build kinda trying to learn as i go got the manual in hand and should be getting it put back together today or tomorrow more pic will follow and im sure now that all the easy stuff is out o the way ill be having a bunch of questions.
Old 9th May 2012
sep69's Avatar
sep69 sep69 is offline
Sportster/Buell Model: XL "NHRS 1250" R
Other Motorcycle Model: Honda vf750c
Other Motorcycle Year: 1995
sep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of light
Very nice package you got there mate
Just take your time and you'll be alright.
If I can do it you sure can too.
You've also came to the right place for questions.
There are very knowledgeable forum members around. They sure helped me plenty when I was doing my conversion.
And keep the pics coming
I know a joke about UDP but you might not get it.
Old 9th May 2012
Ran into an issue ring end gap is off horribly on one cylinder gonna go take some pictures of it now. Should have checked this out before i tore it down but we all make mistakes.
Old 9th May 2012
kgi4x4's Avatar
kgi4x4 kgi4x4 is offline
Sportster/Buell Model: hugger 883
Sportster/Buell Year: 96
kgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nicekgi4x4 is just really nice
gap to wide or to narrow...narrow is easy fix wide ant.
96 XL883/xb12 hugger chopper aka the Rusty Steed
Old 9th May 2012
I just went out did a double check on the gap and i was right its way off i used the method that everyone else does and came up with the ring gap showing .025+ thats as thick as the feeler gauge i have goes and still had room. Checked at the bottom just for the hell of it and the bottom is still in spec. here are a few shots.
here is the piston in the cyl using it to measure how far down the ring is also threw a level on there to make myself feel better knowing the ring is level.
Here is a pic of the measurement you can see the gap in the back which is noticable by eye compared to a good one. i didnt get a shot to compare the two though
Old 9th May 2012
proturn's Avatar
proturn proturn is offline
Sportster/Buell Model: 883c/1203xb
Sportster/Buell Model #2: 1994 XL1200
Other Motorcycle Model: 1998 Heritage ST
proturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to beholdproturn is a splendid one to behold
Are you sure it's the rings and not one cylinder is bigger than the other? Just a thought.
Matt~https://www.facebook.com/pages/Those-Dyno-Guys/543280495733900
Old 9th May 2012
Im sure that cylinder is shot. only thing to revive it is a bore and use oversized piston. So im now on the hunt for another Cylinder to try to keep my costs low. Spoke w/ Dan at NRHS he confirmed what i was dreading to hear.
Is there a diff between front and rear cylinders? Are they interchangeable?
Old 9th May 2012
proturn's Avatar
The cylinders are exactly the same.
Old 10th May 2012
kgi4x4's Avatar
why not just use your stock 1200 jugs? or did i miss something...
Old 10th May 2012
As far as I know I cant use xb pistons with xl1200 cylinders
