0 1974 Ironhead
0 24633-77 Breather assembly
0 Ei
Last Post: Serious Blac
0 New from Utah
0 Post season carnage
0 De-lowing a Superlow with Progressive Monotubes?
Last Post: FuriousGeorg
0 Exhaust Clamp Fitting
Last Post: Yochstein
Last Post: norseXL
0 Rubber mount Oil tank Vent line Routing
0 Need help on bolt size - 92 XL1200, mid pegs
Last Post: r4fthrs
0 Reflectors...Yeah, or Neh
Last Post: 60weight
0 1250 Conversion troubles
Old 10th January 2005
Chicago Nick's Avatar
Chicago Nick Chicago Nick is offline
Sportster/Buell Model: 1200c
Chicago Nick has disabled reputation
Default Tuning Question
Hows it goin everyone,
I just finished installing the following on my 04 1200c (taxes paid):
Screamin Eagle performance coil
Screamin Eagle ignition mod
Magnecor 8.5 mm plug wire set
Screamin Eagle performance plugs
I was wondering if I need to do a dyno tuning after the install or anything else. All I have done so far is install everything, so is that it or do I have some other stuff to take care of.
Also, I will be installing Screamin Eagle cams pretty shortly, and I was wondering if I needed to do any type of dyno tuning or anything else after cams go in.
Thanks a lot for the help,
Nick
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
G-day welcome to the forum
Oh here we go again, LOL
These items that are mentioned on your bike that you have cosmecticly installed will not need to be dyno tuned. What h-p has been gained by these items? Maybe 2-5 h-p if that at all. Once you install the cams all the other that was mentioned will benefit the total package.
Yes, before and after the cams get your bike dyno tuned for your satisfaction.
RTFS
Ride That F'N Sportster!!
willprevale's Avatar
willprevale willprevale is offline
Other Motorcycle Model: '06 Scarabeo
willprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura about
I'll bet they love you at the local stealer's. xllent01 pretty much said it and I personally doubt the 2-5 hp increase. Those things are probably helpful but should have been last on the list.
What anyone else thinks of me is none of my business.
I got the SE cams, SE ignition & SE coil for a total of $230 off of ebay brand new, so I had to go for it. After I bought it all I installed everything I could by my self (all but the cams). I will have to a HD or an indy install the cams. Normally I would have one for chrome but I couldn't pass up the deal.
Didn't mean to infer anything negative. Too many start off with ignition improvements hoping to gain HP. Those things are just about last on the list. You can probably do the cams yourself but you'll need the FM. If you get stuck, just holler.
Willprevale,
No problem with the negitive response, thats the info I look for here (along with a million other things). I just couldn't pass the deal up. Do you think any dyno tuning is needed with the improvements I've made (including cams), or is it strickly to see the improvements on oaper? Also, what does FM stand for.
Thanks,
Nick
FM = factory manual. The improvements you made will not be noticeable on a dyno. I'd probably do it after the cam change tho. It all depends on the kind of riding you do. Remember that dyno tunings are generally at the peak rpm for optimum HP. I don't spend a lot of time in that range so I could care less for that extra 2-5hp that isn't noticeable for the type of riding I do. However, if I'm going for ET slips, that's a different story.
Similar Threads
Ignition Module Question 0ut1aw Sportster Motorcycle Motor - Top End 13 12th April 2005 01:10
fine tuning question Joe S. Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 4 16th February 2005 20:14
Cam choice question shooter Sportster Motorcycle Motor - Top End 3 31st January 2005 20:36
Stupid question about controls Mechano Sportster Motorcycle Motor - Top End 22 28th January 2005 00:37
