Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
Last Post: gravydog
0 1972 tank fitment
Last Post: 72 Ironhead XLH
Last Post: Airbozo
Last Post: nibroc
0 going tubeless in pretubeless 9 spoke mags
0 Help me with gas cap...
0 Sportster or Street Bob
Last Post: joes95bobber
0 1977 xlch starter issues
Last Post: russzx6
0 Primary Oil INSANITY!
0 Lowell, MA weekly moto night (Tuesdays)
Last Post: tvon
0 Blues & Brews 2018
Last Post: tvon
Old 10th May 2012
s2pro's Avatar
s2pro s2pro is offline
s2pro is an unknown quantity at this point
Default Primary and motor / oil
Hi,
I have a simple qustion please:
Can I put the same oil in a Sportster XL1200 '97 CASTROL GTX 20W-50?
for primary and motor?
Old 10th May 2012
Sportster1200C's Avatar
Sportster1200C Sportster1200C is offline
Other Motorcycle Model: Sprint 175SX
Other Motorcycle Year: 1973
Sportster1200C is an unknown quantity at this point
should be able to, I run Mobile 1 20w 50 synthetic in mine.
Old 10th May 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
Should be, dont see why not.
Old 10th May 2012
Crosshairs's Avatar
Crosshairs Crosshairs is offline
Sportster/Buell Model: Its Black and shiny
Crosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond reputeCrosshairs has a reputation beyond repute
You need to be sure that its wet clutch compatible....it will be fine for the engine,but I would stick with a motorcycle specific oil for the primary
Old 10th May 2012
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond repute
Personally I use Syn3 in engine and B&M Trick Shift in my primary/trans. The B&M was recommended by clutch mfg when I replaced clutch. I used Formula + prior and never had any problems. I was advised NOT to use Syn3 in primary as that was too slippery and some have experienced clutch slippage. That said, I would caution against using a "regular" type motor oil in the primary. I would use something that is compatible with friction plates for your primary.
Denny
Old 10th May 2012
s2pro's Avatar
Thank you for all message.
So the CASTROL GTX 20W-50 is dyno (mineral) maybe is better to put Amsoil 20w50 in the primary/transmition? this is syntetic
Old 10th May 2012
Crosshairs's Avatar
Amsoil is fine, its what I and many other use, but be sure to get the Motorcycle specific one..It will say Motorcycle right on the bottle
http://www.amsoil.com/storefront/mcv.aspx
Old 10th May 2012
s2pro's Avatar
Here is a good link: http://www.harley-performance.com/ha...idson-oil.html
"For Sportster 883cc and 1200cc motorcycles, the AMSOIL Synthetic 20W-50 Motorcycle Oil is recommended for both the engine and transmission"
Old 10th May 2012
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Is Castrol 20-50 V-Twin recommended and is it OK for wet clutches?
Old 10th May 2012
Bob Bob is offline
Sportster/Buell Model: 883 sportster
Sportster/Buell Year: 95
Sportster/Buell Model #2: 883
Sportster/Buell Year #2: 95
Other Motorcycle Model: Yamaha XS650
Other Motorcycle Year: 1980
Bob is on a distinguished roadBob is on a distinguished roadBob is on a distinguished road
I use Amsoil 20/50 in my 95 883 Sporty and it is my understanding that my bike has a dry clutch so I even add Tufoil motorcycle engine treatment and I have never had any clutch slippage problem. The bigest surprise was how much easier the trans shifted no more clunk except going from neutral to first gear.
