0 Cartridge Conversion?
0 How do you upshift?
Last Post: Sprtstr1200s
0 Photo Gallery for XL Forum Team Members!
0 This Week in my Shop
0 48 Handling
Last Post: Thyratron
Last Post: squekster
0 Error B2116 & 2117
Last Post: tester
5 To Hone Jugs if replace Piston Rings?
Last Post: groovemeisterus
0 79 starter housing torque values
0 Oil line routing on an 80
Old 12th May 2012
Motorhead52's Avatar
Motorhead52 Motorhead52 is offline
Sportster/Buell Model: 883 sportster
Other Motorcycle Model: BMW
Other Motorcycle Year: 1973
Motorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura about
Default ATF Dextron Mercon
Hey we have a local Indy with the idea of useing ATF in our primary chain, clutch and tranny combined EVO is he nuts??????
Old 12th May 2012
mach1charlie's Avatar
mach1charlie mach1charlie is offline
Sportster/Buell Model: XL 883/1200
Sportster/Buell Year: 92
Other Motorcycle Model: RZ350KLR650GT750KZ1000C10
mach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the roughmach1charlie is a jewel in the rough
Made my clutch slip more on power shifts. most people dont run em as hard as me.
Old 12th May 2012
rejeanprimeau's Avatar
No because you can choose from a least six way of thinking.
1 = 20-50 dyno MA, cheap and reliable.
2 = 20-50 synthetic, durable and smooth shifting but can lead in glaze clutch plate if riden hard; drag and tire smoke show.
3 = 50 or 60 dyno MA, smoother but need warming in cold climate.
4 = 80-90 gear oil MA, very smooth plus excelent gear wear protection, can lead to clutch pack hard to disengage.
5 = ATF oil, hard on the gear but good performance on engaging and disengaging clutch.
6 = 50 dyno oil (BradPenn) Ma with ford differential liquid enhancer for positraction. Wow, no other way of describing it. The mix I use.
Make sure you choose yellow metal safe oil MA
Old 12th May 2012
I've been useing Red Line in the tranny and Golden Spectro in the motor on mine
Old 12th May 2012
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
I've been using B&M trickshift ATF
The semi-synthetic version felt (shift-feel) the same as the old sportstrans fluid.
The full-synthetic version felt better than the old sportstrans fluid.
Both seemed to have the same consistency as the old sportstrans fluid (not thick like gearoil)
Ed
The Only Y2K dual-set 883C
So Cal
Old 12th May 2012
Vanmor's Avatar
Vanmor Vanmor is offline
Sportster/Buell Model: Sportster 883/1200
Sportster/Buell Year: 1987
Other Motorcycle Model: Yamaha XV750 Virago
Other Motorcycle Year: 1982
Vanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura aboutVanmor has a spectacular aura about
I ran it in the primary of my 56' Triumph bobber.
Having seen the inside of the Mazda manual transmission on my old Ford Ranger (uses ATF), I recommend NOT using ATF.
Vance
Old 13th May 2012
toe's Avatar
toe toe is offline
When I run out of B&M trickshift I'll probably try dexron III-H.
It's used in my sister's manual transmission saturn vue. I figure if it can be used in a 3600lb car, it should be fine........
Might have to buy Dexron VI, just make sure it says it meets Dexron III-H specs on the bottle......
Old 13th May 2012
JohnK's Avatar
JohnK JohnK is offline
Sportster/Buell Model: Dearly Departed XL1200C
Other Motorcycle Year: 2000
JohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant future
I've used Amsoil synthetic ATF in my Sportster since I bought it a year and a half ago, zero problems. I may try Type F on the next change, that stuff is grabbier.
ATF is engineered specifically for transmissions with wet clutches, and is also used in the majority of manual transmissions today. The indie that certified my bike thought I was nuts. Last business he sees from me.
John from Windsor Ontario
'00 FXDL
Old 13th May 2012
toe's Avatar
toe toe is offline
Dexron III-H is preferred over Dexron VI for manual transmissions even if the VI bottle says it meets III specs.............
Old 13th May 2012
racerwill's Avatar
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
I've used Dexron in my Sporty for years.....it's designed perfectly for wet clutches.....and it's perfect for most manual gearboxes.....
Ww
master wizard
[B][COLOR="Red"]Super Moderator[/COLOR][/B]
[FONT="Book Antiqua"][B][U]RIP Mr Jimi[/U][/B][/FONT]
"All The Way"
