0 Stock 883 cold blooded
0 1977 Bright Blue
0 Not charging issue!
Last Post: Jowniofownio
0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
Last Post: jammantoo
Last Post: lugster
Last Post: lugster
0 79 ironhead
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 20th January 2008
64physhy's Avatar
64physhy 64physhy is offline
64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold
Default Question about RK air shocks
I have a dumb question. I just got some RK air shocks from the bay. How do you add air? They have brass plugs. Do I need to buy air stems now?
'00 1200 with some stuff done to it.
"The strength of the wolf is the pack, the strength of the pack is the wolf."
Yes, you will need the lines and line caps and collars that hold the lines in place, run to a t-schrader valve so you can air them.
Be aware that the manual for my bike say for a single rider, 5-10 pounds, and 15psi for two up riding.
This is why Harley sells a hand air pump for the air system.
There is a big warning never to use a compressed air to air them, it can blow the seals out of them.
I have seen were some use a single schrader pre-side, this can lead to them being uneven, and give you a very uneven ride.
SpartanDen's Avatar
SpartanDen SpartanDen is offline
SpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond reputeSpartanDen has a reputation beyond repute
You can get a fill kit from dealership that has all fittings and lines, with a single fill valve. A bit pricey, but once installed, you have one point to fill and adjust, and both shocks will be set equally. I have my fill valve located on left side mounted to one of the rear fender strut bolts. But imagination will take you far as well!
Denny
SpartanDen's Avatar
Oh yeah.... I also run these empty or up to 4-6 psi solo and have run up to 15-17 two up and loaded bags. Make sure you get one of the hand pumps for the shocks....they have a micro adjusting valve so you can adjust in 1/2 psi increments!
bills bikes's Avatar
bills bikes bills bikes is offline
Sportster/Buell Model: xl883c
Other Motorcycle Model: 2 gold wings
Other Motorcycle Year: 7684
bills bikes will become famous soon enoughbills bikes will become famous soon enoughbills bikes will become famous soon enoughbills bikes will become famous soon enoughbills bikes will become famous soon enoughbills bikes will become famous soon enough
go to napa to get the air valves about 3.00 dollars apiece
XLFREAK XLFREAK is offline
Get the air valves at NAPA or Ace hardware and the Progressive air balance kit like the one on the link.
http://www.denniskirk.com/jsp/produc...06&skuId=58318
Old 30th January 2008
64physhy's Avatar
After looking all over town, I finally found them at NAPA. If I can't keep the pressure even, I'll probably eventually get the whole kit, but I'll see how this works first.
snowman's Avatar
snowman snowman is offline
I got the micro pump off eBay to pump up the shocks.
You can't just throw a compressor hose on it and fill it up because the chamber is real small...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Old 31st January 2008
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
That link is for forks not rear shocks.
64physhy's Avatar
Yeah. I'm about to get one from ebay. Jireh has them listed cheaper than I've found on ebay, but they're out of stock. That's twice I've ordered from them, and twice they've been out of stock.
