The Sportster and Buell Motorcycle Forum - The XLFORUMŪ
Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUMŪ > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Ironhead Sportster Motorcycle Talk (1957-1985)
Last Post: jordan1200
Last Post: conv90
Last Post: hscic
0 1972 tank fitment
0 primary chain temp.
Last Post: x1_guy
Last Post: Crash7557
Old 21st January 2008
acb2's Avatar
acb2 acb2 is offline
Sportster/Buell Model: ironhead 1000
Sportster/Buell Year: 1981
Other Motorcycle Model: HD-FXD
acb2 is an unknown quantity at this point
Default Only one cylinder runs
Hi, yesterday I tried to run my bike (XLH 1981) and I needed the car battery to start it.
But the problem was that only the rear cilinder runs, but the front one didnīt.
I hadnīt got the tools there, so I still havenīt check if itīs an electric (plugs, wires..) or a mecanic (valves, pushrod...) problem.
anyone with a similar problem? What do you think I need to check first?
Thanks. Acb2
hintocycle's Avatar
hintocycle hintocycle is offline
hintocycle is an unknown quantity at this point
Mine tends to do the same when its cold, but if I start it and dont let it warm up all the way and goose it a little it will foul a plug every time. Check your plugs then wires and you will probably be fine with one or the other. Also check where the plug wire goes into the coil mine broke in there and the wire boot help it inplace without me knowing until I tried to put the plug wire back on and the wire fell out of the coil. It sounds like a dead plug though. Have fun. Start on the easy stuff. cheers
CourtHouseCustom CourtHouseCustom is offline
Sportster/Buell Model: Iron
CourtHouseCustom is on a distinguished roadCourtHouseCustom is on a distinguished roadCourtHouseCustom is on a distinguished road
I take it what you mean by "only the rear cilinder runs" is that the rear if firing and the front is moving fine just not firing. If this is the case, I would check the electrical end of it first. Start at the plugs and work your way to the plug wires, coil, wiring to breaker and ignition, then the ignition/points. Somewhere within all of those items, you should find your problem. Hope that helps.
D.J.
Court House Custom
CosmoTG's Avatar
CosmoTG CosmoTG is offline
Other Motorcycle Model: Kawasaki Vulcan 1500
CosmoTG is an unknown quantity at this point
Start with the easiest first. Plugs. It could be anything of course but swapping plugs and wires is a simple task...Cos
OutlawTexan67's Avatar
OutlawTexan67 OutlawTexan67 is offline
Other Motorcycle Model: FXDBi Street Bob
Other Motorcycle Year: 2007
OutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura aboutOutlawTexan67 has a spectacular aura about
I would check if it is even firing first on the front cyl first,if it is firing then more than likely you are in for a top end rebuild.
Ain't No Head Like an Ironhead !!!!!!!
Chris
http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=13392 My Gallery
http://outlaws-iguana-ranch.com Outlaws Website
http://i258.photobucket.com/albums/hh266/OutlawTexan67/My%20Ironhead/Gifs/BigRotatingSkull.gif "Ironhead Mafia" European Chapter
garbiker's Avatar
garbiker garbiker is offline
Sportster/Buell Model: 883
Sportster/Buell Model #2: old ironhead .
Sportster/Buell Year #2: ???
Other Motorcycle Model: 900 kaw z1
Other Motorcycle Year: 73
garbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the roughgarbiker is a jewel in the rough
OK do this pull the plug will let the spark jump under the boot to the plug. let it run and it will clear up I have let mine run for a few miles this way and saves pulling plug as will clean up a wet or oil plug from sitting if it ran good when you parked it then as you ride push the boot back down good luck a old trick I have used for years
Old 22nd January 2008
acb2's Avatar
Thanks everybody, Iīll check first the electrics posibilities.
Thanks again.
linex82 linex82 is offline
Sportster/Buell Model: XLH Ironhead
Sportster/Buell Year: 1982
linex82 is an unknown quantity at this point
I'd swap just the plugs first - one thing at a time. This happened to me, and the front one was bad. I ended up just replacing them both, because the bike was new to me at the time. I tried to pull the plug and see if it was jumping - and shocked the bejezus out of myself. (and laughed about it, of course)
garbiker's Avatar
well no need to try and tell you guys any thing. 50 years ex on harleys?? IT will work. From a old harley mechanic. gar
Old 23rd January 2008
Shadowdog500's Avatar
Shadowdog500 Shadowdog500 is offline
Sportster/Buell Model: XLH-1000
Other Motorcycle Model: Honda Spree
Other Motorcycle Year: 1987
Shadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enoughShadowdog500 will become famous soon enough
I will give this a try if i ever get this problem. I assume this clears out oil or water from within the boot?
Thanks,
Chris
XL ForumŪ - Linson Media LLC
