Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
0 1977 Bright Blue
Last Post: ericfreeman
Last Post: jammantoo
0 Value of a Boattail?
Last Post: valvebeater
Last Post: lugster
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
Last Post: gravydog
Old 8th June 2012
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Default 88ci Buell M2
HAMMER / Axtell 88ci Kit
HAMMER PERFORMANCE Sledge Head Porting Service
Red Shift 723 Cams
Custom Exhaust
S&S Super D carburetor
This is a race bike built for the AHDRA "Hot Street" class. Hot street rules have a spec gas that effectively limits compression, and they don't allow raised ports, nor do they allow Ti rods or multiple carbs or anything like that. They actually have a template they put into the intake port to make sure you didn't raise it, or raise the floor above the level of an XB head's floor. So it's a bit of a challenge to make big power within their rules, although HAMMER Dan seems to have a handle on it
The pipes on this bike were designed for top end power only. Note how the torque peak is at 6500 rpm ... horsepower is torque times rpm, so to make a big horsepower number, you do things to move the torque peak to the right, which is another way to say you optimize cylinder fill at high rpm. This pipe design does that at the expense of low/mid range power, which is inconsequential in this kind of racing. It's reverting very badly on the left side of the chart, and the cams have a lot of overlap so the reversion is playing hell with the motor. But it doesn't matter for this application.
We were having trouble with the tach pickup on this day (we've since replaced it). Since I didn't have one clean pull where the tach pickup worked properly through the whole rpm range, I plotted 3 similar pulls to fill in the gaps.
Click Here to Contact Me
Old 8th June 2012
Awesome numbers. Is this a bike Dan plans to ride?
Old 8th June 2012
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud of
Wow, great job. Amazing power. steve
Old 8th June 2012
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Thats sweet! nice job!
Old 8th June 2012
aswracing's Avatar
It's all Hammer Dan's work, he did the whole thing. I might've calculated the pipe dimensions for him is all.
Old 8th June 2012
A 4 liter V8 eater's Avatar
DAMN!!! That takes the cake
Old 8th June 2012
Stock cases?
Old 8th June 2012
Those cams are 4 speed cams and they never made a 4 speed Buell M2 so I would say they are most likely S&S cases.
