Last Post: Hank21113
0 Won't rev past 1200
Last Post: Aocasio
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
Last Post: jordan1200
0 too bad
0 Head gaskets.
Last Post: ezmerf
Last Post: robistro
Last Post: felis
0 newby from Australia
Last Post: Veeflys
Last Post: Crosshairs
0 seeking advices
0 Dynatek DC6-5 coil
0 Cream
Last Post: jakewalter
Last Post: seajay
Last Post: seajay
Last Post: JKKO
0 H4 bulb
Last Post: andy_t
Last Post: cazz1000
0 Speedo cable lube
Last Post: JacksBrother
0 Oil use/smoking
Last Post: gpydeski
Old 8th June 2012
il67bp's Avatar
il67bp il67bp is offline
il67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to all
Default 200 rear tire with 18" or 19" rim?
Anybody running this and Have pics? I know there's going to be work involved but I'd like to see what it looks like on a sportster. Thanks
Sent from my BlackBerry 9930 using Tapatalk
Old 8th June 2012
81Fe's Avatar
81Fe 81Fe is offline
Sportster/Buell Model: 1969 XLCH
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH 900
Sportster/Buell Year #2: 1965
Other Motorcycle Model: XLH 1000 75th Anniversary
Other Motorcycle Year: 1978
81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of
Its not going to happen with a stock swingarm. I run a 19'' rear with a 120 tire on it and i only have about a 1/4'' gap between the sides of the tires and the inside front of the swingarm. This is as close as I would go, since the tire will swell at speed.
The swingarm gets pretty skinny in the front where it bolts to the frame.
If you are going the custom swingarm route, I'm sure someone can make you one thats extra wide. I'm not sure that the standard 200 conversion swingarms would work for a 19'', they still taper down and are pretty skinny in the front where it joins the frame.
*EDIT* I'm speaking about the 1979-2003 style swingarms. I have no idea what the measurements of a rubber-mount swingarm are, but judging from pictures they get pretty narrow in the font too. Sorry, I replied to your thread before I saw that you have a rubber-mount.
Fear no Evo.
Old 14th June 2012
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
What tire do you run on the 19" rear? How wide is the rim? I have a 19" rear with a 27.5" flat track tire on it and want to get a street tire that is around the same size.
Old 19th June 2012
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud of
Huge rear tires are for looks on these bikes. The cause the bike to handle poorly and it takes so much hp to turn them you can measure the loss on a dyno.
Old 19th June 2012
81Fe's Avatar
I laced my rear wheel myself. Its a stock Sportster rear hub with a stock sportster 19'' front rim laced to it. My tire is about 25'' tall anda bout 110mm wide.
Its is the Avon speedmaster 19'' Rear. It looks sweet but isnt very sticky...
Old 20th June 2012
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
This has nothing to do with Buell photos; moving to (Sportster) 'Tires, Wheels, and Brakes'.
Folkie
South East England Riders
Old 24th June 2012
Big Rob's Avatar
Big Rob Big Rob is offline
Big Rob is just really niceBig Rob is just really niceBig Rob is just really niceBig Rob is just really niceBig Rob is just really niceBig Rob is just really niceBig Rob is just really niceBig Rob is just really niceBig Rob is just really niceBig Rob is just really niceBig Rob is just really nice
saw a vidio on youtube of a guy with an iron that put a 200 on using a different rim went to chain for clearance and wider fender he had a how to on there,from what i gather the rubbermount swingarms are already wider than on my 97 but im not sure dont take it as stone !!!!
