Last Post: Diogenes415
Last Post: BrokenIron
Last Post: lugster
0 Feeling in trouble.
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
Last Post: Jollly Rogers
Old 9th June 2012
NH-JK's Avatar
NH-JK NH-JK is offline
Sportster/Buell Model: 883
NH-JK has a spectacular aura aboutNH-JK has a spectacular aura aboutNH-JK has a spectacular aura aboutNH-JK has a spectacular aura aboutNH-JK has a spectacular aura aboutNH-JK has a spectacular aura aboutNH-JK has a spectacular aura aboutNH-JK has a spectacular aura aboutNH-JK has a spectacular aura about
Default New Guy Here...W/ a question!!! (cable extentions with 14 inch mini apes)
Hey guys,
I just picked up a 1999 Sportster 883 for $1000. from a friend. I just bought a set of black Burley 14 inch mini apes.
I have been told that some people need to get the cable extentions and others have found enough slack to run the bars with out the extentions....
Can anyone confirm or deny!!!! thanks for all the help. Cant wait to start modding.
Old 9th June 2012
ptotoole ptotoole is offline
Sportster/Buell Model: Sportster 883/1200
Other Motorcycle Model: 1988 Harley Electraglide
Other Motorcycle Year: 1988
ptotoole is an unknown quantity at this point
More than likely longer cables will be required, but, just my thoughts.
I have changed handle bars from original sportster bars to pull backs, and was able to use the original cables, but cables had to be carefully rerouted.
Old 9th June 2012
td67mustang's Avatar
td67mustang td67mustang is offline
td67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura abouttd67mustang has a spectacular aura about
I just did 12's, I had to do a new brake cable but all other we ok. Throttle would be tough to go father, clutch is questionable...
Old 12th June 2012
deathtrapsporty deathtrapsporty is offline
Sportster/Buell Model: 95th anniversary
deathtrapsporty is on a distinguished roaddeathtrapsporty is on a distinguished roaddeathtrapsporty is on a distinguished roaddeathtrapsporty is on a distinguished roaddeathtrapsporty is on a distinguished road
probably gonna need new cables brother. while you're at it, i suggest cleaning up the bars, ie getting all the wiring and switches off and moved elsewhere. looks cleaner and it makes changing bars later much simpler and faster
Old 12th June 2012
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Most mini apes are 11 or 12 inches. Your probably going to need longer cables with the 14" apes. No one really knows until they get to that point in their work. But I think 14 inches is probably too much. It almost certainly will be for the front brake line.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 12th June 2012
iron9813's Avatar
iron9813 iron9813 is offline
iron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud ofiron9813 has much to be proud of
I put 12" mini apes on my Iron a coupla months ago. I was able to use the existing clutch cable and throttle cables, but had to get a new brake line and wiring extensions for the switches. I drilled the bars and ran the switches internally, and I am very happy with the results.
2010 Iron 883 - The Black Pearl
Old 12th June 2012
Big_Baazzoo's Avatar
Big_Baazzoo Big_Baazzoo is offline
Bike Builder
Sportster/Buell Model: XLH Lo 1200 conv.
Sportster/Buell Year: 1989
Big_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really niceBig_Baazzoo is just really nice
Well, they will either be long enogh or not, but if they are not, there are no "extensions". You just get new ones. J&P cycles will have whatever you need. Might I suggest you go ahead and get braided brake lines anyways while you are at it?
http://img48.imageshack.us/img48/2952/bettyandbuddysigql4.jpg Ride Free!
Old 12th June 2012
motorend's Avatar
motorend motorend is offline
Senior Master Bike Builder
Sportster/Buell Model: XL1200N (Sold)
Other Motorcycle Model: FXDL
Other Motorcycle Year: 2014
motorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud of
I put the Burly 14 inch narrow apes on mine and bought the wire kit that Burly offers. Well worth it. The stock cables would not have reached.
Old 13th June 2012
Wilks132 Wilks132 is offline
Sportster/Buell Model: 883R
Wilks132 is on a distinguished roadWilks132 is on a distinguished road
Check out my other post (a few down from here) the burly cable kit is good and a great easy way to do it. Just make sure you get the kit for the 12 inch apes if youre going with 14's. their cables are long as hell for some reason. I have 12 inch R6C bars and got the 12 inch kit cuz they dont make a shorter kit. heres a pic.. the cables are crazy long!!
Old 13th June 2012
motorend's Avatar
OK. I got the 14 inch apes with the 14 inch cables and it looks fine. I can see why you feel that way. It looks like you got 16 inch cables with 12 inch apes. Or its the same length for the 12 and 14 who knows. But they definitely fit neat on mine.
