Last Post: blindfredy
0 DK's Definitive Ride Report - Some of the Best Scenic Roads Out West - Tons of Photo'
Last Post: spoon
0 first harley- help!!
Last Post: Hellbent_4
Last Post: cantolina
Last Post: mac93
0 oil cooler or not?
Last Post: Jason's Sporty
0 Engine dies when choke off
Last Post: shovithead
0 90 in. Build
Last Post: mac93
0 newby from Australia
Last Post: GeoK
0 Intro from New England
Last Post: GeoK
0 Airtech Streamlining is a Rip-Off Compamy
Last Post: dragstews
0 Head gaskets.
Last Post: sevenyears of famine
Last Post: friday
Last Post: guitarfish
0 oil pouring out on right side
0 Sunday 20th May 2018: Hope Cove
0 new oil lines
Last Post: 69sscamaro
Old 9th June 2012
Txn's Avatar
Txn Txn is offline
Sportster/Buell Year: 07
Txn is on a distinguished roadTxn is on a distinguished road
Default Road king shocks
So I went out and bought a pair of rk shocks today, put them on my nightster and hated the look. I found a website called bitchinbaggers.com that will tear them down and shorten them to whatever length you want for $175. I consider myself pretty mechanically inclined and my dad is and has been a machinist for 20+ yrs and can machine anything into what I want or need. So with all that said what is different or what is changed to give the shock a shorter length
Old 9th June 2012
mxr33 mxr33 is offline
Sportster/Buell Model: xl1200n
Other Motorcycle Model: rmz450,z50r,xr50,klx110
mxr33 is just really nicemxr33 is just really nicemxr33 is just really nicemxr33 is just really nicemxr33 is just really nicemxr33 is just really nicemxr33 is just really nicemxr33 is just really nicemxr33 is just really nicemxr33 is just really nicemxr33 is just really nice
what lentgh did you get? you can run them with lowering blocks to get the hieght back where you want them. there was a how to shorten 13 to 12 that may apply but not sure. if i find it ill post a link.
grady, 2009 XL1200N, H-D mini apes, H-D forward controls, V&H side shots
Old 9th June 2012
Txn's Avatar
Txn Txn is offline
Ther are 13 inchers. And I'm weary about the angle a lowering block would put on those shocks
Old 9th June 2012
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
So which part number/length did you buy. Have you seen this thread with the various part numbers/lengths?
I've been under the impression there's been a couple of members that have shortened them. My understanding is that they just shorten the rod and rethread it. Look at this thread about how to disassemble the shock (and specifically rejeanprimeau's posts).
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 9th June 2012
Txn's Avatar
Txn Txn is offline
I got the 54565-09 13 inchers. And idea that write up on how to disassemble them I plan on using that to take them apart just trying to figure out which part to shorten once I get them apart
Old 9th June 2012
rejeanprimeau's Avatar
The damper rods has to be cut to limit the lenght. They use an 11 mm. 1.25 thread. You have the 09 shock, the top has to be rotate 90 degrees for dissambly.
Old 9th June 2012
Txn's Avatar
Txn Txn is offline
So cutting the damper rod down by two inches should give me 11 in eye to eye correct? And is the dissasembly different than in the thread Dan referenced earlier?
Old 9th June 2012
XLXR's Avatar
XLXR XLXR is offline
You need to be careful that the shocks bottom out before anything else hits. Nightsters have a reflector that hits the belt guard. Other bikes hit ECU, or wires under the fender.
Old 9th June 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Those are genuine HD shocks.
+ 1 on what both these gentlemen said. Also, if when you have the shock apart take the time to take pics of the shortening process. That would be a nice addition to the RK threads that others have on here.
One other note. Shortening the shock will make them stiffer.
George
--Thomas Jefferson
Old 9th June 2012
XLXR's Avatar
I am not sure what guys do to shorten RK air shocks. Cutting and shortening the springs does increase the spring rate and that should make it feel stiffer. But I am not sure if there is another way to shorten the RK air shocks.
