13th June 2012
JESTER SYNDICATE
Posts: 12,211 Sportster/Buell Model: NRHS Stage II 1250-R Sportster/Buell Year: 2005
Madnss is correct, if you read through my build thread, my stated goal at the beginning was not a max HP build. It was built primarily with streetability and dependability in mind. For me the combo I've put together works well.
Sic Semper Evello Mortem Tyrannis
13th June 2012
Posts: 15 Sportster/Buell Model: Sportster 48 Sportster/Buell Year: 2010
ok, ill have to look at that at some point. cause thats kinda what im wanting to go for as well, but maybe with some extra cajun seasoning...
13th June 2012
Posts: 6,880 Sportster/Buell Model: 883 Xl Sportster/Buell Year: 1992
Rite on rico.....To the original poster.....Your trying to pick a cam out of a million choices for a stock bike, then a ported bike.
Tough to do, unless your trying to reinvent the wheel, go with what works and is proven. The cams you mentioned are great cams. I just think the majority of the population in the sportster world has had good luck with stock bikes and ported bikes using cams such as the 497, n4, 536, n6 to a name a few that came to mine.
If you want to go bigger. the cams you named are great, but the world proof of them is not there as much. Bigger cams that have proven themselves. 585, 567, redshifts, chicken 536, 575, To name a few.
Ive always stuck with what works and is proven. im not a wheel inventor, thats up to you to decide, But the above cams, work with the proper head work. good luck buddy and welcome to the forum
13th June 2012
you want some cajun seasoning.....check out grinds build on this forum. he is also on hammer perfs website,
My engine is also on hammers website and this forum.
Thats a little bit more spicy of a build then n4's if thats your cup of tea.
13th June 2012
Thanks alot for the info and advice guys, i really appreciate it. now to just take it an make it work. an i gotta say for this bein only my first week on here, i love it! Hard to believe ive have my bike almost two years, and only now got on this. Thanks again!
13th June 2012
A Million Facts & Figures
Posts: 9,780 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
bad48, a good head porter can look at your flow data and do some calculations that point him to the best grind for your particular heads and horsepower target. If you're going to have Zipper's port your heads, I highly suggest that you talk to Zipper's and get their recommendation, as the rest of us can only guess (unless you want to publish your flow data, in which case I'll run the numbers).
