Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
  #41
Old 14th June 2012
randy3934's Avatar
Sportster/Buell Model #2: 1979 and 1969 XLCH
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1980
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
I'm not hearing anything about valve adjustment.
Old 14th June 2012
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
we need to find out if it was put back together correctly first, then move to valve adjustment
Old 15th June 2012
ss243b ss243b is offline
Sportster/Buell Model: 78 sportster
Sportster/Buell Year: 78
ss243b is an unknown quantity at this point
Originally Posted by 72 Ironhead XLH View Post
what were trying to find out is
1 did you remove the cam from the cover,
2 install the cam in the engine,
3 install the cam cover,
4 install the advance system,
5 install the inner plate, install the reluctor(the part that spins around)
6 and set timing.
Yes to all, i will start from the beginning, new top end on the bike pistons, valves etc. Put it back together and it ran but was not taking oil from the bag, pulled the oil pump to find it was locked up and cracked, ordere a new pump took the case off to see if the gears were messed up, everything was fine, when i pulled the cover a gear fell out so i re alligned all the gears on there timing marks installed new oil pump, adjusted push rods put all the ignition stuff back on and thats where im at, no running at all
Old 15th June 2012
I do have spark, the plugs arent wet but the have a little gas on them and smell like gas. And the popping comes out of the exhaust and carb(fire comes out of the carb) air filter is not on
Old 15th June 2012
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all2007Low is a name known to all
Aw come on, do the valves, do the valves.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
Old 15th June 2012
I need you to answer the questions in my post 43 first.
Old 15th June 2012
Valves should be fine my mechanic done them and it ran great. Problems didnt start until after i tore open the cam case to replace the oil pump and retime cams
Old 15th June 2012
Yes to all the questions
Old 15th June 2012
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
Well then I'm confused. 1st you say you didn't remove the pickup plate, and now you say you did remove the pickup plate. "5 install the inner plate....". You had to remove it in order to install it.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Old 15th June 2012
I just removed it a little while ago, so yes,
