0 Dreaded carb again
0 oil pump
Last Post: factory rat
0 Please help with muffler identification
Last Post: RKN
0 teflon buttons or circlips?
0 1985 Ironhead, help with dynatek 2000 install
Last Post: atengnr
0 Where To Get Free Air
0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 Intake Seals
0 Piston melted
0 Bob The Chicken
10 Introduction
0 82 XLH in Arkaksas
0 Venhill cable
Last Post: 93trident
0 Help & advice needed
Last Post: Andy Hog
0 My 99 883 c
Last Post: 99-883-c
0 Electrical problems.
Last Post: Andy Hog
0 New to HD
Last Post: Tyler45
0 Cam followers have locked up internally. No movement at all. Why?
0 LED Headlight?
0 Anyone know who can shorten fork tubes?
Last Post: Whitewalls
PlanB, Cuco6924 (75), 1200sporty (64), iron68 (50), LifesHarlequin (37), mattosm (36)
Old 14th October 2005
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond repute
Default carb adjusting- Where are the jets and the mixture screw?
I put on cycle shack slip on mufflers and a K&N a filter. The bike pops every now and then when going slow and I twist the throttle.
I know that I need to rejet the carb and/or adjust the air flow/gas mixture.
I have read Stevo's jetting 101 and his continued post several times. I understand the why's but I still need the hows.
I am a little mechanical and will tackle any project if I have directions.
Does anyone know where I can get expicit directions as to HOW to do the mechanical work?
Do I take the carb off to do it or can it be done on the bike?
I read something needs to be drilled out. WHAT? And where is it? what does it look like? etc?
I would need something similar to a step by step procedure like what comes in a box when you buy bycicles that have to be put together.
thanks
paulieb paulieb is offline
Sportster/Buell Model: XL 883
paulieb is an unknown quantity at this point
here is a dynojet instruction sheet. ( i am not advocating the dynojet )
it has some diagrams that may help.
http://www.dynojet.com/pdf/8134.pdf
paulieb
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Here are some pretty specific instructions...take the carb off the bike first...
They're on another site, but the author is a member here, too..
http://www.sportster.org/tech/carb/rejetting.shtml
When you pull the bowl, (DO NOT TOUCH THE FLOATS!!!)this is what you will see:
The obvious one is the main jet...it is inserted into the emulsion tube...
Sometimes, they will come out together:
You WON'T really need to do anything with this, unless you just want to clean it, which is a good idea....
The pilot jet is sorta hidden in a hole, off to the side of where the emulsion tube is..but you see it here, partially removed:
This is the jet you will want to consider changing....only a coupla sizes at most...
If your stock is a 42, try a 45...etc..
Leave the main as it is....
Here are both jets, and the emulsion tube, removed from the carb:
Now, Here's a pic of the bottom of the carb:
The circled part is where you drill out the plug...
Be careful when you do this....
Put some electricians tape on the end of the drill bit like this:
You only need a hole in the cap.....use a screw to pop that cap off....
Then, your carb will look like the picture above...
THAT is where the mixture screw is....
Once you've done this, soft seat it all the way in (I DO MEAN SOFT!), then back it out 2-2 1/2 turns...a great place to start
NOTE: DO NOT take the mixture screw out.....there's no reason to, and there are parts inside there you don't wanna play with (OR LOSE), or reinsert wrong.....
Put the carb all back together, put it on the bike, and the only thing you should need to do from then on is find a screwdriver that fits into the hole for the mixture screw, to adjust as needed...
See? You can do it!!
Good Luck!
~Chuck
Occam's Razor...
XLF Tuning Stickies
Turbota's Avatar
Turbota Turbota is offline
Chuck ....
Great post!
Great photos!
RoadKingMoe RoadKingMoe is offline
Sportster/Buell Model: XL883 Hugger
Other Motorcycle Year: 2000
RoadKingMoe is an unknown quantity at this point
Those pictures are VERY helpful! If I might add a couple of things to this thread.
Many emulsion tubes have flats for a wrench, 5/16" IIRC. If you use this, you can remove the main jet without removing the emulsion tube.
If you do remove the emulsion tube, the needle jet that sits on top of it may also come out. You can see the top of it in the carb throat. Lower it out carefully so that it doesn't hit the floor, roll or bounce, and be captured forever by the garage gremlins. Also note the orientation of the needle jet if you remove it. It's not the same on each end.
When removing the slow jet, you may need to make a special screwdriver. You need a tip that is wide and thick enough to fill the slot in the slow jet or you can bugger it up. The "slot" is actually two slots, one on either side of the hole, and you need to get good screwdriver tip contact in both of them. Unfortunately, many screwdrivers are wider above the tip and if you get one with a sufficiently wide tip, it's too wide above that. If you try to force one of these down in the cast-in tube, you can crack the carb body. You can always put the screwdriver on a grinding wheel to get this flare out of it.
Let me also add emphasis to drilling the plug carefully. If you let the drill bit "break through" the plug quickly, it can dig into the idle mixture adjustment screw and spin it closed hard. This can damage it. Don't push on the drill. Let the bit do the work.
Hundreds have done this with my step-by-step instructions Catolina linked to on Sportster.Org. Many of them had never turned a wrench before. You can do it too.
cantolina's Avatar
Thanx, Maurice....good points...
And from the man who got me started on this crap....
Old 15th October 2005
awesome instructions guys.
I read the link and matched it back and forth to the pics.
G-R-E-A-T instructions.
I will be doing this myself in a few days thanks to your postsThanks
Paul
Ken Man Do's Avatar
Ken Man Do Ken Man Do is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: '93
Ken Man Do is an unknown quantity at this point
Originally Posted by cantolina
You can do it!!
Great. Now I've got this visual.
Old 16th October 2005
cantolina's Avatar
That's awesome...
Same pic came into my head when I wrote that!
But it was the one from the Geico commercial....
cantolina's Avatar
Paul
That's awesome....
I always get jazzed when someone takes their bike on by themselves...
Its NOT voodoo.....
I never thought to actually match the pics to Maurice's instructions, but, then again, I first learned how to tear my carb apart from HIM (via those exact instructions), so I guess I shouldn't be surprised...
Let us know how it comes out!
