Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Seating and Luggage
Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
Last Post: 72 Ironhead XLH
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
seat, sportster
Old 25th June 2012
viob's Avatar
viob viob is offline
viob is an unknown quantity at this point
Default Another seat question
Hi all,
Does anybody know which seat this is?
Cheers,
Peter
Old 25th June 2012
viob's Avatar
another pic
Old 25th June 2012
Hutch08's Avatar
Hutch08 Hutch08 is offline
Sportster/Buell Model: XL1200X "48"
Hutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of lightHutch08 is a glorious beacon of light
Biltwell Black Diamond Solo Seat
http://www.biltwellinc.com/index.php...ct_detail&p=41
Old 25th June 2012
viob's Avatar
That was quick! Thanks Hutch08.
Old 4th July 2012
viob's Avatar
Hi all,
Instead of opening another thread I add on one more seat related question here.
Finally got the HD solo springer seat on my 48. Still have to get used to the new seating position. What is a bit a problem in my case is that the new position moved quite a bit further to the front so my long legs have not that a relaxed position on the foot pegs anymore.
On a bike somewhere here on the forum I saw this setup
Seems to be the same HD solo springer seat but with another mounting at the back. This makes it sit much lower and I assume the seating position will be moved further back again as well.
In comparison my current setup - although seen from a slightly different angle - looks much higher up and more 'flat' if you compare the angle.
Any idea how the other setup works? Maybe the actual owner is around as well?
Cheers,
Peter
Old 4th July 2012
Hutch08's Avatar
To me it looks like they just removed the hairpin springs and replaced them with rubber stoppers. A lot of guys do this because it's unlawful to mount a spring seat on a bike with rear suspension! HaHa
Have a read through this thread:
http://www.hdforums.com/forum/sports...er-mounts.html
Member YOURADHERE's bike:
That pic you posted looks like HoldFast48's bike:
Old 4th July 2012
viob's Avatar
So you think it's just a matter of shortening these rubber stoppers to lower the seat like on HoldFast48's bike?
Old 4th July 2012
Hutch08's Avatar
Probably, or just used smaller profile rubber stoppers.
PM HoldFast48 and ask him what he used, looks like it's one single stopper in the middle.
Or do what these guys did... LoL
Old 5th July 2012
dafy dafy is offline
Sportster/Buell Model: xl1200x 48
Sportster/Buell Year: 2012
dafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the rough
I went a similar route to Holdfast, but used a thick piece of rubber and velcroed it in place, then cut up some leather to hide the clusterfcuk of wiring:
To be a Rock, and not to roll...
