0 900 heads contd..
Last Post: Keithybloodygeorge
0 Oil Tank question
Last Post: jordan1200
0 1967 XLCH stroker project
0 Fact or Fiction - HP Claims
0 NewProject
Last Post: Rodzilla
Last Post: vagrant318
0 Cylinder Piston kits
0 Thinking about buying a Ironhead
Last Post: ericfreeman
5 Pre-Oil the motor somehow after long Non-running?
0 Trouble Code B1611?
Last Post: Jcolleyoh
5 Wasted spark ?
Last Post: Magneto Sportster
0 surges and/or hunting on 1200 EFI's
Last Post: whittlebeast
Last Post: kaveebee
0 More of a reintroduction
Last Post: k9unitb
0 Iree's jukbox joint
0 Battery life with total loss ignition
Last Post: Diogenes415
Last Post: lugster
0 Viking bags??
Last Post: gravydog
0 the far west burbs of Chicago
0 Diagnostic help
Last Post: BradX13
Old 7th July 2012
Horace18 Horace18 is offline
Loose Nut
Sportster/Buell Model #2: XLCR
Sportster/Buell Year #2: 1978
Other Motorcycle Model: FLHTK
Other Motorcycle Year: 2014
Horace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the roughHorace18 is a jewel in the rough
Default Gauges glazed over
The gauges (speedo & tach) on my 78 XLCR have turned white. When wet, they are a bit more transparent but then they dry to a white colour again. What can I clean this off with that won't damage the lenses any further? Can it be cleaned or does it need to be polished/ground off? Any suggestions would be welcomed. Thanks
2004 XL1200C Lava Red NRHS 1250 Stage III Patriot Defender Mikuni HSR42 TC88A SE 575 Cams - spells FUN
Old 7th July 2012
FearlessFrisbee's Avatar
FearlessFrisbee FearlessFrisbee is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1957
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Indian Scout 741
Other Motorcycle Year: 1941
FearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really nice
There was a long post on this about a month ago, search the forums and I'll look too.
Old 7th July 2012
Here is the latest post:
http://xlforum.net/forums/s...ighlight=gauge
and another:
http://xlforum.net/forums/s....php?t=1488155
Old 7th July 2012
75IRONHEAD's Avatar
75IRONHEAD 75IRONHEAD is offline
Sportster/Buell Model: SPORTSTER
Sportster/Buell Model #2: SPORTSTER
Sportster/Buell Year #2: 1997
75IRONHEAD is an unknown quantity at this point
get a headlight restoration kit.i would do it for you but i think you are little to far for me.i do windsheild repair and headlight restoration.
Old 7th July 2012
sportymike02's Avatar
Sportster/Buell Model: 1200c
sportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond reputesportymike02 has a reputation beyond repute
a green scotch brite pad works wonders
Old 7th July 2012
ReddTigger's Avatar
Its at least a 3 step process.
1) sand off oxydation
2) remove sanding marks
3) glaze and protect.
FLITZ makes a kit that'll work well for the general public. Google FLITZ headlight restore
States I've Ridden in
71.3 hp 70.8 tq
Old 7th July 2012
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
This worked on the Speedo on my Honda CB350 Cafe project.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
Old 8th July 2012
Loose Nut
Thanks all for your suggestions, will work through these.
