0 Ironheads
0 Salutations y'all
Last Post: Fridge
Last Post: Vohnsen
0 67 Sportster build
0 There’s shade tree brakes; then there’s the dark side of shade tree
Last Post: sdsbassist
Last Post: Grumpy-Biker
0 no rear brake light
Last Post: geoff
Last Post: goblin_dust
Old 7th July 2012
blazingtorque's Avatar
blazingtorque blazingtorque is offline
Sportster/Buell Model: XL1200 CUSTOM
blazingtorque is an unknown quantity at this point
Default Sportster won't start!
Hi, MY 2008 XL1200 has been in my garage for the last two months, just gone to start it and all the lights and battery seem fine but when I put the switch to run it makes a high pitch noise then I go to start it and all I get is a clicking and the motor won't fire up.
Any suggestions on what might be the problem?
Old 7th July 2012
rymax101's Avatar
rymax101 rymax101 is offline
rymax101 will become famous soon enoughrymax101 will become famous soon enoughrymax101 will become famous soon enoughrymax101 will become famous soon enoughrymax101 will become famous soon enoughrymax101 will become famous soon enoughrymax101 will become famous soon enoughrymax101 will become famous soon enough
most of the time it is just the charge on the battery. even if the lights come on the battery might not have enough amps to crank the motor. i would either jump the bike off another battery and ride it to charge the battery or put the battery on a charger for a couple hours and then see if it will start.
If these dont help it may be that you battery is bad.
2009 Iron 883 w/1200 conversion, fuelpak, r6c 8" z bar, shortshots,
Old 7th July 2012
vlmuke's Avatar
vlmuke vlmuke is offline
Other Motorcycle Model: Fat Bob
Other Motorcycle Year: 2015
vlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to behold
+1 on charging the battery
I don't know it all Nor do I claim to
Old 8th July 2012
Sorry, should of said the bike is on a Optimate charger most of the time anyway.
Could it be another problem ?
Old 8th July 2012
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Have you done anything recently to the bike?...anything? Removed the battery?...changed grips....washed the bike..etc etc.
Have you removed all the fuses and relays and applied dielectric grease to the terminal ends? If there a large amount of corrosion on the relays you are better to just replace them. That should be step #3 on 07'-09' sportsters. #1 is making sure you have a fully charged battery and #2 is making sure that the battery cables are WRENCH tight on both ends! They are notorious for loosening up and simply tightening them up with a screwdriver is not good enough.
The clicking you are hearing could be a bad relay or arching between the battery cable and the battery or ground.
If you have got past that point the next step would be too take your two relays you currently have and swap them and see what happens.
Lastly, you need to check to see if you have any diagnostic trouble codes stored.
Cosmo
Old 8th July 2012
motorend's Avatar
motorend motorend is offline
Senior Master Bike Builder
Sportster/Buell Model: XL1200N (Sold)
Other Motorcycle Model: FXDL
Other Motorcycle Year: 2014
motorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud of
Most of the time won't do it on an old battery. I left mine off the charger for 10 days and the same thing happened. Got the clicking. Placed it on the charger for 2-3 hours till the light was green and it fired right up.
Old 9th July 2012
ShadowMan ShadowMan is offline
ShadowMan is an unknown quantity at this point
I just experienced a similar situation, lights came on and fuel pump primed. I hit the starter button and all I heard was a click and everything went dark.
It turned out my battery connections were loose, tightened those and it fired right off.
Old 10th July 2012
Mozvader's Avatar
Mozvader Mozvader is offline
Sportster/Buell Model: Sportster Xl 883 Custom
Other Motorcycle Model: 2014 Street Glide Special
Mozvader is just really niceMozvader is just really niceMozvader is just really niceMozvader is just really niceMozvader is just really niceMozvader is just really niceMozvader is just really niceMozvader is just really niceMozvader is just really niceMozvader is just really niceMozvader is just really nice
I notice your bike is a custom and most likely has the HD anti theft system with the "smart" fob. Check the battery in the key fob before you start tearing the bike apart.
Sounds like your ignition kill is kicking in.
Old 15th July 2012
Thanks for the coments and suggestions, after 24 hours on a charger bike fired up, so will now invest in a new battery.
Does anyone know if you can fit a heavy duty battery with out making any mods?
If so where can I get one and what is the model of the battery?
Thanks again for all your comments
Old 15th July 2012
jguynn jguynn is offline
Sportster/Buell Model: None
Sportster/Buell Year: N/A
jguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nicejguynn is just really nice
When the battery in my 07 took a dump I ordered the direct replacement AGM from O'Reilly(sp?) auto parts. Good price, perfect fit, and plenty of juice.
John
