0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Last Post: Wharfcreek
0 Primary Oil INSANITY!
Last Post: cotton1
0 Cartridge Conversion?
Last Post: XLXR
Last Post: MXHD55U
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 1979 oil routing diagram
Last Post: The Crusher
Last Post: gravydog
Last Post: Edster
Old 3rd August 2012
dafy dafy is offline
Sportster/Buell Model: xl1200x 48
Sportster/Buell Year: 2012
dafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the roughdafy is a jewel in the rough
Following up...and copy/pasting my post from 'the other forum' lol:
Getting there. Figured out how to do this without tapping the frame.
Made the first bracket, but with such thick metal I had to make it very small, so I nixed it.
So now I've used thinner metal, but have made two brackets, ie that fit together.
I will JB weld them so it's nice and strong. Still shaping etc. but here's the un-designed bracket:
Approximate look on the bike:
And I found a neat place for my mirror to help clean up the bars, since I've relocated my front signals down low:
I'm using 2 motor mounts for the front of the tank lift, ordered from eBay:
http://www.ebay.com/itm/Used-Genuine...f31420&vxp=mtr
I'll use all black hardware up front to try and make it "invisible".
Once I've finished the above bracket, I'll start on the coil/key.
Probably same idea, work with metal that is thin enough for my tools to shape,
double it and JB weld the two brackets together...
I'd prefer thicker metal (what I'm using is 2mm-and-a-bit thick according to my calipers,
so when doubled+JB Welded together, I'll get about 1/2cm in thickness or just under...plenty sturdy I hope.
To be a Rock, and not to roll...
Old 13th August 2012
Finished, overall I say it's 90%...best I could do with my tools/experience:
black_ice_02's Avatar
black_ice_02 black_ice_02 is offline
Sportster/Buell Model: Nightster 1200
black_ice_02 has disabled reputation
right on! good way to turn this thing around. good improvising and the brass bolts really seal up the look
Old 14th August 2012
Thanks man. Really gave me the bug to start doing these sorts of things more often, and get some training. How to weld etc.
Unfortunately at my location (I rent) the best I can do is MAP/oxygen and that's not really big enough to do anything major, though (so they say, I'm hoping to make brackets and braze/weld a sissy bar with it...wish me luck). My landlord...or rather his insurance company...would probably have a cow if I brought home O/A tanks lol. And those 120V TIG/MIG welders, so it seems, are not up to task.
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
You need to get some rubber on those rear mounting bolts or the JB weld is not going to last long.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Thanks...how thick do you suggest? I know where to buy rubber washers if that will work?
mr.coffee's Avatar
mr.coffee mr.coffee is offline
Sportster/Buell Model: XL883N
mr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to beholdmr.coffee is a splendid one to behold
I had problems with my a/c cover rattling after I cut away the back; I dug a couple of rubber washers out of my spare nuts & bolts bin. Most likely they were for toilet tank bolts. Check the plumbing section of your local hardware store or big orange box. For smaller washers, maybe faucet washers.
-m
