Last Post: gravydog
0 1972 tank fitment
Last Post: 72 Ironhead XLH
Last Post: Airbozo
Last Post: nibroc
0 going tubeless in pretubeless 9 spoke mags
0 Help me with gas cap...
0 Sportster or Street Bob
Last Post: joes95bobber
0 1977 xlch starter issues
Last Post: russzx6
0 Primary Oil INSANITY!
0 Lowell, MA weekly moto night (Tuesdays)
Last Post: tvon
0 Blues & Brews 2018
Last Post: tvon
Last Post: tvon
Old 26th July 2012
rontech rontech is offline
rontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished roadrontech is on a distinguished road
Default Strange noise coming from primary
The bike makes this squealing/rubbing noise only when the bike is moving, and the noise slows down when the bike does. I just replaced my clutch adjusting screw assembly bearing about 3 weeks ago. Is it possible for this bearing to fail after only 500 miles or so or could it be the clutch hub bearing? Has anyone had a clutch hub bearing go bad? If so, what were the symptoms? Other than that the bike runs fine, shifts good, etc.
Old 27th July 2012
sportsterdoc's Avatar
sportsterdoc sportsterdoc is online now
Other Motorcycle Model: Triumph Bonneville
Primary chain too tight?
Old 27th July 2012
threat357's Avatar
threat357 threat357 is offline
Sportster/Buell Model #2: 1200 CHOP PROJECT
Sportster/Buell Year #2: 1997
Other Motorcycle Model: 1200 CHOP PROJECT #2
Other Motorcycle Year: 1992
threat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to all
Check your drive belt adjustment. Too tight?
Old 27th July 2012
1250IRON's Avatar
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light
You sure it not coming from your brake rotors? Probably not if it is squealing.
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
Old 27th July 2012
Primary chain is within specs. I checked it when I replaced the throwout bearing. I don't think it's that anyway because the primary chain moves with the engine RPM's. This noise slows down when the bike does. It's not the brakes, they are fine. I checked the final drive belt a few weeks ago, it was within specs. I'll check it again. The noise seems to be coming from the primary, I'm leaning towards the clutch hub bearing. Don't know until I can get it apart. Don't have a clutch spring compressor tool, no one around here seems to have one. I do have access to a complete CNC machine shop, I could easily make one, if I knew what it was that I'm making. I need dimensions. I'll check the final drive belt again, maybe the compensator sprocket. I hope to have it fixed this weekend. I have been relying on the bike for the commute every day since my truck got wrecked 2 months ago, so I need the bike to stay operational until I can get the truck bodywork repaired. Since I have to ride the bike all the time, it's a real PIA when I need to do any work on it.
Old 28th July 2012
threat357's Avatar
Only when the bike is moving and changes with engine rpms. Hmm. I'm still gonna say check belt tension like I mentioned earlier, but also check for anything making contact with a tire under a fender. I've seen where the rear wiring harness under the rear fender came loose and was hanging down making contact with the tread of the tire as the wheel rotated. Also have seen rear fender hardware make just enough contact with rear tire sidewall to make noise like that. Just a couple of thoughts. Wheel bearings?
Old 28th July 2012
a45junkie's Avatar
a45junkie a45junkie is offline
Master Bike Builder
Sportster/Buell Model: XLH883/1200
Sportster/Buell Year: 96
Other Motorcycle Model: CX500
Other Motorcycle Year: 84
a45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nice
check your front sprocket nut too. they can come loose.
96 XLH883/1200
BUB Reinhart 2-1 exaust fitted with supertrapp muffler 24 disks
big sucker stage one
progressive suspension
Old 28th July 2012
redi2ride's Avatar
redi2ride redi2ride is offline
Sportster/Buell Model: Sportster 1200cc
redi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud of
I don't have time to give you the links. check out my profile's threads posted about the same thing. we found the answer. Flame retardant also has a thread to fix your prob.
"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." -- Benjamin Franklin
Old 31st July 2012
I went for a ride, leaned waaay over so I could try to pinpoint the noise. It isn't coming from the primary. It seems to be coming from the rear wheel. I get bike home, jack it up, turn wheel by hand. Must be wheel bearings, but there is no noticeable play in the bearings but they seem to make a "groaning" noise about every 1/2 revolution of wheel. Wheel bearings? Checked belt tension, it's good. Rear wiring harness isn't touching tire. So I let bike down off of jack, proceed to ride down the street to pinpoint the noise again, this time the noise disappeared. Been riding the bike for 2 1/2 days without the noise, now it started up again, but not as loud. Looks like wheel bearings are on the list...
Old 31st July 2012
threat357's Avatar
Told ya
Haha, but really, post a follow up after replacing 'em. Let us know is that took care of it.
Sent from my DROIDX using Tapatalk 2
