0 Ironheads
Last Post: Island Dude
0 2016 Sportster Rear Wheel Removal w/ABS Brakes
0 Slip on muffler
Last Post: Tucsonmax1
0 Decman's Birtday
0 New member in MD
Last Post: RKN
0 Dissembly and Assembly of starter shaft nut on Ironhead
Last Post: blk80bike
0 acc pump
Last Post: lwh1950
0 What's your helmet?
Last Post: 83XLX
0 Rear tire
Last Post: 83XLX
  #51
Old 3rd August 2012
mikethebike61's Avatar
I converted my 77 CH to 1979 rear disc brake with all OEM sprocket cover, internal shield, M/C and linkage. I'm running an 'o' ring chain with a 22 tooth and have no side clearance problems. When it was OEM 1977 and a 24 tooth the non 'o' ring chain 'customized' the internal shield!!!
Old 3rd August 2012
wedge's Avatar
wedge wedge is offline
Originally Posted by mikethebike61 View Post
Same thing. That tight spot is caused by the fact the sprockets are not PERFECTLY round.
Or, in the case of an old worn chain, there are places that are more stretched than others (this really shows up when the chain needs oil badly).
Old 3rd August 2012
sturgmachinist's Avatar
sturgmachinist sturgmachinist is offline
Sportster/Buell Model: xl 1000
Sportster/Buell Year: 74
Sportster/Buell Year #2: 76
Other Motorcycle Model: Panhead
Other Motorcycle Year: 56
sturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of lightsturgmachinist is a glorious beacon of light
I'm 90% sure the battery acid is a non issue with the chain. It was washed immediately and coated with a heavy does of chain lube and an industrial WD-40 type spray. No other signs of corrosion. I think the battery acid just led me to notice the chain a little closer. All the cracks are on the tire side, which is wear the chain was rubbing the battery tray at the bottom of the hard tail.
As far as the O-ring chain, I have had some stretching but never any clearance problems. Both my sprockets are stock with no sprocket cover on the front. I'll look again for any rub spots, but none that I know of.
So, I'll pony up for new sprockets and go ahead and do the rear wheelconversion. As far as chains, I've always heard o-ring chains were better, if I solve any clearance issues, is there any reasons for one chain over another?
"we, outlaws on God's property,
Fling out imagination beyond the skies,
Wishing a tangible good from the unknown."
74 Custom Rigid XL,
"stuff"
Some dirty chrome, a little duct tape and lots of rust
One headlight, one tail light, one brake, and lot's of balls!
Old 3rd August 2012
CaptCaveman's Avatar
CaptCaveman CaptCaveman is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Various
CaptCaveman is an unknown quantity at this point
O-ring chains are lower maintenence, only an occassional shot with lube mostly to prevent rusting.
Still crazy after all these years
Old 3rd August 2012
sunchild2071's Avatar
sunchild2071 sunchild2071 is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLH1200
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Chopped Shovel
Other Motorcycle Year: 1978
sunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant futuresunchild2071 has a brilliant future
If you're gonna pop for an o-ring chain, check out x-ring chains. All the same benefits, fewer drawbacks. I thnk DID is one manufacturer.
Disclaimer: I'm not the expert on this stuff, be sure to seek further opinion/knowledge.
