Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > REGIONAL FORUMS > United States of America > Southwest > California
Last Post: wharg
0 Bars on C Riser?
0 Clutch Spring plate poll
Last Post: jammantoo
0 crack in head
Last Post: slamtry
Last Post: 883openpipes
0 the far west burbs of Chicago
Last Post: lugster
Last Post: BrokenIron
0 More of a reintroduction
Last Post: lugster
0 05 and 73
0 900 heads contd..
Last Post: TT60
0 Racing tem up with Hero moto corp
Last Post: retired
0 The White Bike is the Right Bike Thread.
0 Starter motor
Last Post: sleighcrane
0 Found my bike on Google maps
Last Post: gravydog
5 Am I looking for Trouble ?
Last Post: Crosshairs
0 WTF Happened
Old 4th August 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Default California Carb/EPA New Resident Rules Questions.
I want to know if I buy a brand new bike here in PA before I move to Cali if the new bike has to have California Emissions?
Is there a time/mileage thing that would make it Cali exempt?
Thanks for any information.
George
--Thomas Jefferson
Old 4th August 2012
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant futuretoe has a brilliant future
You can bring an out of state (non-CA emissions) into CA if you're moving into the state with it. No limitations on mileage (7500) that a existing CA resident has to worry about if buying out of state bike.
I'd have it registered in PA first.
I've heard you can buy CA emission bikes out of state. If it actually has CA emissions, you might be able to skip the PA registration.
Ed
The Only Y2K dual-set 883C
So Cal
Old 4th August 2012
Gcram399's Avatar
I asked the dealer here in Pa and he didn't have a clue. He said I'd have to ask someone in Cali.
I found a bike that I liked and didn't want to do anything until I was sure.
I didn't want to have to special order a bike with Cali Emissions Equipment if it wasn't necessary. That's an extra $200.
I will get it registered in Pa first.
Old 4th August 2012
willypscustoms's Avatar
willypscustoms willypscustoms is offline
Sportster/Buell Model: xl883c
willypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of lightwillypscustoms is a glorious beacon of light
Just don't move to California then you won't have to worry about it.
Old 4th August 2012
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
California Vehicle Code section 4150.2 does not mention this.
However, see this http://www.dmv.ca.gov/pubs/brochures...cts/ffvr29.htm
which applies to CA residents bringing in a "foreign" vehicle.
Old 4th August 2012
Gcram399's Avatar
Ok, That should cover me on the purchase but what happens a couple years down the road when I try to sell the vehicle? Will I have an issue then?
Old 4th August 2012
Don't know why you would, based upon CVC 4150, pertaining to M/C registration.
Old 4th August 2012
XLXR's Avatar
XLXR XLXR is offline
The California DMV is so screwed up, I wouldn't even risk buying a bike and trying to bring it into the state. They have been making it harder and harder to bring in out of state bikes and cars every year. Every DMV clerk you talk to will give you a different answer. It may not matter if the bike was registered in another state or not. Read the rules carefully.
Old 4th August 2012
Gcram399's Avatar
Yea, this is going to be a catch 22 situation for the wife and I.
We would have no problems buying new vehicles now while we are still in Pa. because we have both been at our jobs for a very long time but then the CARB stuff might come back to haunt us later.
On the other hand, if we move and both start new jobs we won't have any work history to get financing on new vehicles.
I know I'm not leaving Pa without my current Sporty!!!
The Cali CARB wackos and the rest of those idiots can kiss my pipe!!
Old 5th August 2012
Originally Posted by XLXR View Post
...Read the rules carefully.
Good idea:
Application for Motorcycle
4150.2. Application for the original registration or
renewal of the registration of a motorcycle shall be made by
the owner to the department upon the appropriate form
furnished by it, and shall contain all of the following:
(a) The true, full name, business or residence and mailing
address, and drivers license or identification card number, if
any, of the owner, and the true, full name and business or
residence or mailing address of the legal owner, if any.
(b) The name of the county in which the owner resides.
(c) A description of the motorcycle, including the following
data insofar as they may exist:
(1) The make and type of body.
(2) The motor and vehicle identification numbers recorded
exactly as they appear on the engine and frame, respectively,
by the manufacturer, and any other identifying number of the
motorcycle as may be required by the department.
(3) The date first sold by a manufacturer, remanufacturer,
or dealer to a consumer.
(d) Any other information that is reasonably required by
the department to enable it to determine whether the vehicle
is lawfully entitled to registration.
