0 Value of a Boattail?
Last Post: valvebeater
Last Post: jammantoo
Last Post: lugster
0 Viking bags??
Last Post: cotton1
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 2001 883 'customizing' log
Last Post: cotton1
0 rpm jump pulling in clutch
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: jordan1200
Last Post: Racepres
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
Last Post: gravydog
5 Am I looking for Trouble ?
biltwell ironhead
Old 18th August 2012
Dirtyd1 Dirtyd1 is offline
Sportster/Buell Model: Xlch
Sportster/Buell Year: 1970
Dirtyd1 is an unknown quantity at this point
Default Struts
Will10" biltwell struts bolt straight onto my 1970 iron? They say they'll bolt onto most sportys, but in my experience nothing bolts straight onto my bike
Old 20th August 2012
trappnman's Avatar
trappnman trappnman is offline
Sportster/Buell Model: XLCH- old school chop
Sportster/Buell Year: 1973
Sportster/Buell Model #2: 1981 XL
Other Motorcycle Model: Norton HighRider
Other Motorcycle Year: 1971
trappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant future
not familar with that brand of struts, but can see no reason why they would not bolt right on- whether that length is correct or you bike, you would have to measure the current shocks on the bike, and then plus or minus that from 10" to see if clearance etc would be correct
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
10" may be too short for an older Sportster. The best way to tell is to put your bike on a bike jack, remove your shocks, and lower the jack until the tire touches the underside of the fender. Then measure the distance between the shock mounts and add whatever clearance you're comfortable with. That's the shortest you can go without other mods.
Not worried about clearance heights, she already has short struts on her, 10" will raise her by an inch or so, just wanted to know if biltwell struts will fit without any mods? Thanks guys
trappnman's Avatar
I don't see why they would not, just by the nature of what a strut is.
