Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 19th August 2012
bobberman66's Avatar
bobberman66 bobberman66 is offline
Sportster/Buell Model: XL883C - Two Tone Blue
Other Motorcycle Model: Honda CM400T
Other Motorcycle Year: 1980
bobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the roughbobberman66 is a jewel in the rough
Default Cam Identification
I've searched the forums, but didn't find what I was looking for. I'm wondering if there are numbers stamped into the cams, that are visible, if I pull off the cam cover. I am curious if my XL883C has stock or aftermarket cams installed. She pulls hard straight to the red line, I have a hard time staying in the seat.
Thx
Remember rubber side, down!
Wrench Head of the Popes of Hell MC
rocketmangb's Avatar
Stock cams for an 883 Rubbermount are "D" grinds and they are stamped as such
The 1200's are "W" grinds and stamped
FI 883's use "W" cams I believe
03 and earlier 883 and 1200 rigids use course tooth pitch "D" grinds
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
