0 New member in MD
Last Post: ReddTigger
0 67 Front Axle Reinstall/Tighten procedure
Last Post: ss396
0 Help me with gas cap...
0 Sportster or Street Bob
0 Burly Brand x Billet Proof
Last Post: BILLETPROOF
0 Cad Plating
Last Post: conv90
0 1968 XLCH Oil Leak
Last Post: 72 Ironhead XLH
0 Running CVP velocity needle. shims?
Last Post: CVPerformance
0 Drive Chain Adjustment
Last Post: class of 82
Last Post: RKN
Old 30th January 2008
bills bikes's Avatar
bills bikes bills bikes is offline
Sportster/Buell Model: xl883c
Other Motorcycle Model: 2 gold wings
Other Motorcycle Year: 7684
bills bikes will become famous soon enoughbills bikes will become famous soon enoughbills bikes will become famous soon enoughbills bikes will become famous soon enoughbills bikes will become famous soon enoughbills bikes will become famous soon enough
Default glide front wheel
i have a 05 custom. i would like to put a 16" on the front . will a 04 electra glide front fit if i change the bearings ? the hub with is what iam thinking about. i want to use a 110 90 16 tire. i mite be able to get the front and rear for less then a 100 with tires [ tires aren't much good ] and rotors. hope to hear from some of you out there on what you think good or bad. going for the bagsters look.
thanks ahead of time
p.s. look out for my spelling.
langner91's Avatar
langner91 langner91 is offline
Other Motorcycle Model: FLHTC - Finally!
Other Motorcycle Year: 2008
langner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the rough
I don't know what else you would have to change, but I gotta believe that an e'glide front wheel is WAY wider than any sporty front end will allow. Isn't it?
I know the FL front end on my Heritage is quite a bit wider than my '06 Sporty and I doubt that tire would fit.
It would look awesome, but I think you will need a different front end (triple trees at least).
~Corey
shotgun46's Avatar
http://xlforum.net/forums/s...hreadid=103597 look at this !
Sportsters Rule ! :banana
stock rim is 2 1/2" and i think the glide should be 3" with a 110 tire it should fit. i guy on here put a 130 on and had to take 1/16" off the legs. the main thing is the hub. he use a sportster hub lace to a glide wheel.iam just trying to take the esey way outbut i may haft to go the long way.
Old 31st January 2008
<<<<<bump>>>>>
