0 Clutch Spring plate poll
Last Post: seajay
Last Post: Vohnsen
0 Fact or Fiction - HP Claims
0 More of a reintroduction
Last Post: spitfirechopper
0 Cylinder Piston kits
0 Trade Chrome for Black?
0 Bars on C Riser?
0 1967 XLCH stroker project
Last Post: kaveebee
0 crack in head
Last Post: slamtry
Last Post: 45Brit
Last Post: kaveebee
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
Old 13th September 2012
OldSchoolBully OldSchoolBully is offline
OldSchoolBully is an unknown quantity at this point
Default Drag pipes, effects?
I have done a search and didn't quite come across what I was looking for. Let me put this in context by saying I have zero experience with the HDs and am speaking as someone who has has only messed with Japanese bikes. When I bought my ride the PO threw in a set of slash cut drag pipes. When running these regularly, does the sportster require any sort of rejet or adjustment? The oversensitive Kawasaki carbs needed rejetted for air pods so I was wondering if it was an issue on the Harley. Thank you in advance....
BobWLR's Avatar
BobWLR BobWLR is offline
BobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of light
Drag pipes only work with apehangers.
Kidding, I feel funny this morning.
Well it all depends on if the bike was properly jetted before you changed the pipes. If there was a major change in the amount of restriction in the exhaust then I would say yes you may need a rejet but if only a minor change in exhaust then probably get away with tuning the air jet screw. It all depends on what the previous owner did to it. Adjusting the air screw will tell you if you need a larger or smaller pilot jet.
Check out the Stickies for carb tuning. Many Jap bikes use the same but slightly different Kehein carbsonly the Jap bikes have a decent air tuning screw and nylon sleeves on the slide.
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
S&S has a great video on utube about the effects of drag pipes.
wilkin4's Avatar
wilkin4 wilkin4 is offline
Bike Builder
Sportster/Buell Model: XL1200 S/ sold
Other Motorcycle Model: Suzuki M109R/ totaled
Other Motorcycle Year: 2008
wilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond repute
Good find, the video was well done... thanks.
On the Highway to Hell, no stop signs, no speed limits.......
Excellent video. So, no good way to run drag pipes without that loss. They would have been an occasional addition anyway, I don't hate my neighbours enough to ditch the stock pipes entirely. Thanks for all the info.
Post no Avatars!
You can modify the stock pipes to get pretty good performance and not too loud. If it's a 2001, drill a 3/4" hole in the baffle plate that you see when you look into the end of the muffler.
Some knock it out entirely but I prefer the 3/4" hole. It mimics the SE Torque mufflers that hey used to sell back then.
stalkie's Avatar
stalkie stalkie is offline
Serial Fettler
Sportster/Buell Year: 1970
Other Motorcycle Model: Triumph T120,TR6+3 BSA's
Other Motorcycle Year: 1970
stalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond reputestalkie has a reputation beyond repute
Default What a drag
Just picked up some drag pipes, now I've watched the video. I used to run straight through TT type pipes on my Triumph Bonnie, I had to go up from 205 to 220 mains to get it to run right but definate performance increase. (and noise) I'll let you know how I get on, if it dosen't run good they can go on ebay.
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Welcome to the XLForum.
Drag pipes kill your mid range power. A good 2 into 1 system, free flowing air cleaner and a proper tune will give you the most power.
My 72:
My 07:
Your 72 is akin to what I'll one day own. Gotta get a feel for the Harley before diving into the ride everyone warned me off.
As I said, my plan was sporadic use of the drag pipes, once in a while to annoy the local Harley haters, of which their are many. Purely cosmetic, purely for noise. I've seen a few two into ones, it's what I run on my KZ. Best start looking. I have a new K&N air filter to go on, looking for a new less chromey air cleaner (coming from a scruffy/rat background I am adverse to chrome overdose). I'm not doing anything major until I ride the hell out of it.
Old 19th September 2012
stalkie's Avatar
Serial Fettler
Default drag pipes
Well after a bit of fiddling got the bike to run pretty well, maybe lose out a bit in the mid range but not much and the sound on the overun is beautiful. I do live in the middle of nowhere not too many people to upset, I even had one old boy walking his dog tell me to wind it open.
