0 More of a reintroduction
Last Post: k9unitb
Last Post: 45Brit
0 crack in head
Last Post: slamtry
0 Clutch Spring plate poll
Last Post: NZstu
Last Post: 45Brit
Last Post: kaveebee
0 Cylinder Piston kits
0 Bars on C Riser?
Last Post: mattjs666
0 1967 XLCH stroker project
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
0 Fact or Fiction - HP Claims
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
Last Post: kaveebee
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The White Bike is the Right Bike Thread.
Last Post: if6was9
Last Post: Slidesquad24
Old 18th September 2012
the1337aaron the1337aaron is offline
Sportster/Buell Year: 1973
the1337aaron is on a distinguished roadthe1337aaron is on a distinguished roadthe1337aaron is on a distinguished road
Default kicker question
i just installed a vtwin kicker kit on my bike and was wondering if i installed it right. when i go to kick it, the arm stays down and i have to bring it back up with my foot, is this right or is it supposed to spring back up in position? thanks alot
DirtyCory's Avatar
Sportster/Buell Year #2: 1972
Other Motorcycle Model: Sportster 48
Other Motorcycle Year: 2010
DirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud of
its supposed to spring back up. check and see if you have the spring tight enough, but with my first kicker install, i had the same problem and it was due to not enough clearance on the kick shaft bushings. make sure that clearance is good or youll probably crack your cover. should be around .015 clearance from shaft to bushings
If your gonna do something, do it right!
[SIGPIC][/SIGPIC]
antsap's Avatar
antsap antsap is offline
Sportster/Buell Model: 71' XLCH
Sportster/Buell Year: 1971
Other Motorcycle Model: 1956 FLH
antsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura aboutantsap has a spectacular aura about
Can you post a few pictures? It will help us help you
brucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant futurebrucstoudt has a brilliant future
i,had a.similar problem.starter clutch spacer was to short,causing primary chain to rub on starter crank gear nut. checking this would require removing the primary,again,
there's another possibility you could check with out removing the primary. starter shaft thrust plate could have come,dislodged. this is the small wing shaped plate on the kicker shaft on the back side of the primary case. if the shaft get's pushed back at all,while installing the starter crank gear,this s.o.b. will fall of of the pin that locate's it.
The kick start shaft may be jamming in the bushing. Loosen or remove all the bolts for the sprocket cover and see if the problem goes away. On my 1978 i had to install three shims to get the cover aligned so that the kicker would not jam up in the bushing.
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
I agree with Mick, first check the cover. You really got to watch its position as you install and maybe shim. Ther is a sweet spot. You just gotta find it, especially repop parts made for several years of bikes and to Taiwanese specs, although better than China.
do you have to preload the chrome spring a whole lot? cuz i preloaded it once and that didnt do the trick, i was thinking i didnt preload it enough.
DirtyCory's Avatar
i preload mine as little as possible and it comes back with no issue.
check bushing clearances and some of the other stuff mentioned
brianbbs67's Avatar
I have been revived
What about, 2/3 to 3/4 full turn wind up? Even less should recoil pretty easy. Try this, push it down to where it hangs up and then loosen the bottom bolt a little and see if it returns. If not, try again with top bolt. Also grease up the the bushing. I think that has been said.
