0 Ironheads
Last Post: Island Dude
0 2016 Sportster Rear Wheel Removal w/ABS Brakes
0 Slip on muffler
Last Post: Tucsonmax1
0 Decman's Birtday
0 New member in MD
Last Post: RKN
0 Dissembly and Assembly of starter shaft nut on Ironhead
Last Post: blk80bike
0 acc pump
Last Post: lwh1950
0 What's your helmet?
Last Post: 83XLX
0 Rear tire
Last Post: 83XLX
Old 2nd February 2008
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
Default Can a late model front end be fitted to a 77 Sporty??
What sort of difficulties would i encounter trying to fit a 39mm showa front end on a 77 Sporty that came with a 35mm showa front end?. . .All i have been able to find out from the person that has them is its off a 2002 "lowrider" and it has a 19" wheel. . .would it be a softail of sorts perhaps?. .. I'm waiting on getting a heap of measurements off the guy, but in the meantime one of you may have an idea??. . .would the original 77 guard fit ie. same width and bolt spacing?. . .as mine is airbrushed, is there some sort of conversion neck cup set that would be required to mount the triple tree?. .or should i not go there and rebuild my stock front end?
Thanks in advance
Russell
Horse's Avatar
Horse Horse is offline
Sportster/Buell Model #2: XLH 883/1200
Sportster/Buell Year #2: 1995
Other Motorcycle Model: FXDBI
Other Motorcycle Year: 06
Horse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to beholdHorse is a splendid one to behold
Lowrider is a Dyna, and it would have the 1" neck, so you would need to swap out your neck cups, but other than that, it should be a fairly easy swap.
R.I.P. Brother
Mocha Mafioso
hoosier xlc's Avatar
hoosier xlc hoosier xlc is offline
Bike Builder
Sportster/Buell Model: This & That
hoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to allhoosier xlc is a name known to all
Yeah it will fit, watch the fork stops might be in a different location.
Hoot
Old 4th February 2008
archemitis's Avatar
archemitis archemitis is offline
Sportster/Buell Model: 98 xl built to the hilt
Sportster/Buell Year: 79
archemitis is an unknown quantity at this point
i have the same front end on my 67. i put the new cups for the 1 inch neck in, and it worked fine. the stops werent going to work on my frame so i grinded them down, and got a universal fork stop. i also grinded the fork lock tab off of the lower triple tree, it got in the way, and wouldnt work with the ironhead lock.
i put a drum wheel/hub on mine, which was a little bigger problem with the 5/8" axle compared to the 3/4 inch forks...
but if your using the whole front end, wheel and brakes and all, it will be easy. i think my fork stop was from accutronix
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
The 2002 front end would be a good idea. Much better brakes. I've been told the fender will fit.
carmine73's Avatar
carmine73 carmine73 is offline
Other Motorcycle Model: flstfse
carmine73 is on a distinguished roadcarmine73 is on a distinguished road
man oh man would i love front brakes!!!!!!! perhaps back that actually worked would be fun too!
Old 5th February 2008
russzx6's Avatar
The shmuck that i was getting it off went and sold it on me . . .i'm probably a while away from getting mine moving again though, so i will definitly keep an eye out for anothre setup, thanks for all your advise!!
archemitis's Avatar
no big deal theyre dirt cheap, i've seen them go on ebay for 150 complete.
