0 Speedometer hookup - 76 XLH
Last Post: Bow only
0 oil drive and gear timing
Last Post: volvocanadian
Last Post: ronccc
Last Post: Joe_jeep
0 xied or x14ied?
9 CV carburetor gurus...
Last Post: Dougray
0 Resto-Repair 84 ironhead
0 Why cafe a sportster?
Last Post: TUCCI
0 fp3
Last Post: 11alan111
0 Digital odometer
Last Post: shrimp
0 No spark
Old 17th October 2012
devotion devotion is offline
Sportster/Buell Year: 1979
devotion is an unknown quantity at this point
Default Primary drain plug options
Im in the process of mounting a 1979 ironhead motor into an after market hardtail frame. Seems to me like I am not going to be able to access the primary drain plug enough to remove for oil changes. Is there a way to use something...some other way to remove the oil? Think fancy turkey baster!
You need to change the primary oil only once a year so a bit of inconvenience is not so bad.
You can use a drill pump ...
Cost about $20 maybe less. Attach a hose at each end input and output, attach your electric drill, ...
Some guys just remove the primary cover and tilt the bike a bit.
79 has the primary chain adjuster thru the primary cover - might be able to drain it there. I do not as i have not tried it. Remove the nylock nut, remove the stud, ...
Perfect. So with a tube attached and placed in through primary inspection hole, I should be able to reach most of the oil?
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
Or a hand suction pump?
http://forums.aaca.org/attachments/f...uction-gun.jpg
24 beers in a carton. ...24 hours in a day . .. coincidence??
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
Or a Liquivac. I picked one up at Ace Hardware and it works great.
Link to Home Depot:
http://www.lowes.com/pd_97973-60928-2000_0__?productId=3048103&cm_mmc=PLA_LawnGarden-_-OutdoorPowerEquipmentParts-_-gps-_-LiquiVac%20Replacement%20Knobs%20&"cagpspn=pla"
SEMJPM
fergerburger's Avatar
fergerburger fergerburger is offline
Senior Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of lightfergerburger is a glorious beacon of light
or a postivac with the needle-dick attachment
http://www.healthykin.com/p-2211-enc...on-device.aspx
simeli simeli is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 69
Other Motorcycle Model: Sportster
Other Motorcycle Year: 70
simeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud of
Isn't there a primary oil level check plug on the 79? Pull it lean the bike and let it drain out for 10 minutes.
I am not familiar with the 79s does it have a drain for the trans and a drain for the primary as well? Unless your frame has a belly pan welded on you should still be able to access the trans drain plug. If not it would still be a simple matter to drop the primary cover and draining it that way while you have the cover off drill and tap a hole in the bottom of the cover for a plug for future use (not that I would personally do this).
doodah man's Avatar
just wondering how you'd be knowing about that one lol!!!
Video here ...
http://www.activeforever.com/p-1406-...px?ShowVideo=1
The high pressure safety valve is critical when removing primary fluid from your lower unit.
