Last Post: Jeffmazz
0 Getting old is a bitch!
0 Allegheny National Park III
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 Tank flush
Last Post: RandallM
0 High beam not working
Last Post: joe s
Last Post: 84rzv500r
0 My new deer rifle
Last Post: Whitewalls
0 1995 Manual
Last Post: jeffro57
0 Massachusetts 2022
Old 21st November 2012
sep69's Avatar
sep69 sep69 is offline
Sportster/Buell Model: XL "NHRS 1250" R
Other Motorcycle Model: Honda vf750c
Other Motorcycle Year: 1995
sep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of lightsep69 is a glorious beacon of light
Originally Posted by Gcram399 View Post
Well, did you find anything out yet?
I was going to say to pull the plugs and take a look at them. If they are both oiled or oil fouled it might point you towards wet sumping from the oil not being returned to the bag. If only one is oiled or fouled I would look at piston or ring problem.
Just remember that I'm only an arm chair mechanic. A compression and leak down test may be in order. Just three things to try without firing it up.
I haven't had time yet. I'm having two days off the end of this week to do some jobs in my house. But I think we already know what I'll end up doing
And the things you mention are good ones George !
I was thinking of doing a compression test as well.
Thanks for thinking with me NorseXL and George
I know a joke about UDP but you might not get it.
Old 22nd November 2012
sep69's Avatar
Ouch ! 2 sparkplug with oil on them and compression test says Front cylinder 270 And rear 55 psi.
Verstuurd van mijn U20i met Tapatalk
steelworker's Avatar
Other Motorcycle Year: 2016
That doesn't sound good. Time to remove that rear head.
sep69's Avatar
Default Crap....
Found it
The exhaust side of the rear piston is completely gone..
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
Uff da, any clues to what may have caused it?
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
sep69's Avatar
Doesn't look too good now does it ?
A huge chunk of the piston broke off and is now somewhere in the engine case.
I guess that has to be taken out before ever starting the engine again..
Also there is some damage to the engine case looking at the second pic.
Just wonder what could have caused it.
I put my new exhaust on about 50 km before it happened. Could it be that a leak on the exhaust caused this ?
sportsterdoc's Avatar
Other Motorcycle Model: 2022 Triumph Street Twin
Sorry for your troubles, but you diagnosed it correctly in your first post.
As for cause, perhaps a lean condition, but that usually burns a hole directly under the spark plug
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Wow...that's a pretty catastrophic failure. I'll be interested in finding out what caused that.
sep69's Avatar
Well new cylinders and pistons I can buy again.
What do you guys think about the missing piece of the piston ?
That has to come out right ?
I don't think I'll sleep or ride easy with it still in the engine after I get a new set on the bike.
Jörgen Jörgen is offline
Bike Builder
Sportster/Buell Model: S&S XL124" streettracker
Jörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond reputeJörgen has a reputation beyond repute
From looking on the pics, I would suspect too tight piston ring end gap. That kind of piston damage is typical for piston ring seizure.
