0 Value of a Boattail?
Last Post: valvebeater
Last Post: jammantoo
Last Post: lugster
0 Viking bags??
Last Post: cotton1
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 2001 883 'customizing' log
Last Post: cotton1
0 rpm jump pulling in clutch
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: jordan1200
Last Post: Racepres
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
Last Post: gravydog
5 Am I looking for Trouble ?
Old 27th July 2013
Glock Man Glock Man is offline
Sportster/Buell Model: 883 superlow
Sportster/Buell Year: 2012
Glock Man is on a distinguished roadGlock Man is on a distinguished road
vinoo@go:
I also have a 2012 Superlow,I weigh 210 and the stock setup was to soft,so here's what I went to.Progressive 412 shocks,12 1/2 " length,set in middle preload notch.Progressive standard fork springs and used 3" of the included spacer.I left the fork oil alone,just put the springs in.This setup raised the bike about 1" total all around and REALLY improved the ride........best $295.00 I've spent so far,hope this helps.
John[the old]
Old 28th July 2013
XLMACK XLMACK is offline
Sportster/Buell Model: XL1200L/ not L anymore
XLMACK is an unknown quantity at this point
I just bought a 2007 XL1200L. The front end bottoms way to easily. I did read all the stuff on the forum and I don't see a fix. The bike has had a few owners before me so, I'm not sure what has been done. The rear shocks were changed to taller shocks and is definitely over sprung.the bike in the back and the front has about five inches of potential travel when the front end is lifted. When I sat on the bike two inches disappeared , I weight 200lbs. The front end would travel another inch then bottom. There is two inches if travel or fork tube left unused. The bike was unridable. So I bought some progressive springs and installed them with fresh hd type e oil to stock capicity.The sag is now one inch but it still bottoms. The ride is definitely better but still is very punishing on rough roads.
The bike bottoms with two inches of fork tube to travel.
Any ideas?
Thanks
Dave
Old 28th July 2013
XLXR's Avatar
XLXR XLXR is offline
Have you tried to lower the shock preload?
I assume you are referring to the forks here. Either the spring is way too light, or worn out, or you need to add more preload.
Either you bought the wrong springs, or have inadequate preload. I forget which weight Harley type e oil is, but you should probably stay with 10w until you get the spring problem figured out.
Five inches travel in the shocks is unheard of for Sportsters, so that makes me question what kind of shocks you have.
5 inches of travel in the forks is about right for the full length forks, which probably also means the damper tube was changed to a Roadster / Custom tube which has smaller compression damping holes then the other low models, and that means you should stay with 10w oil to avoid over-damping on rebound.
Read the "7 Pages of Suspension" in the Suspension Sticky Index Section. Somewhere is a link to a thread by Whittlebeast which has a spring calculator. Or find one on google. Then you can measure out your springs and see what you actually have. There are enough numbers in the "7 Pages" to help you determine springs you actually need. Setting up suspension starts with getting the correct spring rates, and then understand how all the other adjustment work together.
Old 28th July 2013
XLXR's Avatar
finally got progressive springs on my 883XL in front & o boy what a difference to the ride . now need to change the rear . wanted advice there is a gentleman who has brand new street bob dyna fxdb springs at a low price as he has upgraded to progressive , its .5 inch longer than my stock . should i go for it ? will the ride be any better/worse as these are for a heavier bike ?
I weigh 300 lbs in gear and stuff on the bike. the FX shocks I tried were too stiff for my weight. The shocks would compress through the initial / soft part of the travel and then just stop compressing because the final / hard spring rate was just too stiff. This got a little dangerous in curves with bumps because the tire would skip over the bumps instead of compressing and absorbing the bumps. However, there are probably several different FX shocks, and I don't know about all of them.
Old 28th July 2013
Thanks for the tips XLXR. I re read your 7 pages and low and behold I think I found the solution. I installed the correct or recommend progressive suspension springs. As you said they are designed for long travel suspension and not for low sportsters. The soft rate portion of the spring gets used up and bottoms long before it hits the higher weight.
The other issue I have is that the forks only travel 3 inches of potential of 5.
I will ride the bike to Sturgis next week and get it sorted.
Thanks again
Old 29th July 2013
vinoo@go vinoo@go is offline
Sportster/Buell Model #2: superlow 883
vinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the roughvinoo@go is a jewel in the rough
Default FXDB shocks on sportster 883L
Actuall what you are saying is bang on confirmed by a rider who has thi ssetup, thanks will change to progressive 13inchers & revert
Old 29th July 2013
Originally Posted by Glock Man View Post
vinoo@go:
John[the old]
thanks a lot half of this I have already done will take your advice though i might go with 13 or13.5 progressive at rear. front is exactly what you have done
Old 29th July 2013
XLXR's Avatar
Just jam more preload in there to get rider sag at 1/3 to 1/4 total travel and see what happens. If you still bottom out, add a bit of oil or add air forks. But you can only go so far trying to compensate for a too weak spring.
Old 29th July 2013
darkdesign's Avatar
darkdesign darkdesign is offline
Sportster/Buell Model: xl883c
darkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to behold
on a superlow, i'd go with 13" due to the shorter front forks. you don't want the frame being angled down towards the front, they get twitchy like that.
Old 29th July 2013
wow that was important , cant thank this forum & riders like you enough for the valuable inputs we get in markets like India where HD is new , big bikes are rare , there is almost nil customisation, after market parts are frowned upon etc ... we have along way to go
