0 Another question re: Microsquirt
Last Post: t120r
0 85 Ironhead, Kiffy Stand Question
0 Digital volt meter
0 Clutch adjusting screw
0 Short in electrical system? Confused about points and ignition coil
Last Post: BigMek
0 Pegs vs floorboards
Last Post: riceburner
0 Allegheny National Park III
0 Oil system prime
Last Post: XL Ed
0 ‘67 front drum with ‘70-‘72 front steel wheel?
Last Post: wrkdWS6
0 Aftermarket Taillight Lens Woes
0 The Strociek Project
0 gasket sealant
0 weight loss thread
0 Coulda' - Shoulda' - Woulda' - Solenoid/Bendix?
Last Post: ZTatZAU
0 R.I.P.Meat Loaf
0 Can't install kickstand spring
0 Before and After pictures/Videos of your bike (All Welcome)
Last Post: Ghostdog
0 BEWARE Of SCAMMERS!
0 Ironhead how to video from Lowbrow
Old 6th February 2008
AussieGazza's Avatar
AussieGazza AussieGazza is offline
Proud 2000 XLH 1430 Owner
Sportster/Buell Model: XLH 1430
Other Motorcycle Model: Piaggio X9 250
AussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really nice
Default Fitting an Oil Blowby Hroseshoe to Stock HamCam A/C (with photos)
In another thread I complained that the horseshoe oil blowby adaptor I bought would not work with a 'Universal' A/C mount:
This is how I used the stock A/C hardware.
First measured 2 washers and horseshoe thickness:
Marked this on A/C spacers and parted off on lathe:
Put Breather bolts through A/C baseplace and put cut down spacer on. Worked out where breather hole should be and drilled:
Attached Breather with A/C Baseplate:
How to block off original breather bolts within A/C? Hole is perfect for M8 and I tapped and put in M8 x 15 bolts:
All done. I used a hose with 8mm I/D and passed it over starter and in front of rear swingarm:
On to the next project!
[SIGPIC][/SIGPIC] AussieGarry
I'm not a complete idiot -- Some parts are missing (but on order from EBay).
Supertrapp 2-1 with 18 plates and closed end cap, 11.5" 412 Progressive with Heavy Duty springs and Progressive fork springs. Mikuni 45carb/SE 44 manifold. NRHS 88" with Stage 2 ported 04 heads with 15 degree squish band, SE .536 cams, crane roller rockers and lifters, NRHS Hurricane Adj Pushrods and Collapsible Covers. Ultima prog ign. 180 main jet, 3 turns, 20 idle jet and 97 needle at 3rd notch. AIM 240 Clutch. LRB Z Plus Brake Pads on dual front brakes. Kuryakyn Boss Blade Levers + Forcewinder XR A/C.
HDandME's Avatar
HDandME HDandME is offline
HDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enough
I'd find a way to use some aviation safety wire on those bolts you threaded into the breather bolts. You have one of those back out and it is all over. Nice job on the setup though.
Masshole Rider.
01 1200C.
SEII slip-ons, Big City Thunder baffles
Forcewinder XR, NGK Iridiums
Amsoil 20W-50 all holes
"Roll with the mystery, life is uncertain." -- Indian Larry
