Last Post: jordan1200
Last Post: conv90
Last Post: hscic
0 1972 tank fitment
0 primary chain temp.
Last Post: x1_guy
Last Post: Crash7557
Old 11th December 2012
kwaltz6 kwaltz6 is offline
Sportster/Buell Model: XLh
Sportster/Buell Year: 1979
kwaltz6 is on a distinguished roadkwaltz6 is on a distinguished road
Default Best electronic Ignition for 79?
I am planning on updating the ignition system on my 79 this winter. It currently has points, which are fine when gapped and timed correctly, but I've had 2 issues this past summer with one of the springs on the fly weights coming undone and basically looks like metal spaghetti when I pull the points plate out. So, to save any future hassle I want to update to electronic ignition. Anyone have suggestions on a good product? How difficult are they to time once installed, and what is the procedure? Anyone who's switched from points to electronic notice any significant gains?
'79 Supercharged Fuel Inj's Avatar
'79 Supercharged Fuel Inj '79 Supercharged Fuel Inj is offline
Sportster/Buell Model: XLS
'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold'79 Supercharged Fuel Inj is a splendid one to behold
The previous owner replaced the factory electronic ignition with points???
Anyhow....as for which system is "good", comparing the available systems is like starting a thread on which oil is good.....you'll get pros and cons on every one.....
I'm running a Crane "Fireball" HI4 single fire ignition, and have been very satisfied with it.
Good luck with whatever you end up with!
Magnuson Supercharged, Hilborn Mechanically Fuel Injected '79 HD XLS Roadster.....(and street legal!)
I don't know if they retrofit points or not. 79 was the first year for the EI and the earlier models were still points. I've heard a lot of guys finding points in their 79. Anyway. I'm basically wanting to get ideas on the easiest to time, and any differences between dual and single fire. I know it's all subjective. I want to stay away from any cheap components also, preferably nothing made overseas.
Ultima kit Get a VOES switch too.
I would avoid any of the points replacement systems that keep the centrifugal advance as it is a common point of failure.
Ryder, I'm using an adjustable bendix carb. Using a VOES would require a change over to a CV carb so I can use the vaccume lines, correct? Not opposed to it. I've kind of been wanting to switch to a CV anyway, but I digress. Just want to know what all kind of work/parts/supplies I should be prepared for.
Dash47331 Dash47331 is offline
Other Motorcycle Model: 2011 Self built rigid EVO
Dash47331 is an unknown quantity at this point
My 79 has points also! I don't know if the PO changed them out or what but I have been thinking about an EI system, just haven't decided.
Carb type doesn't matter for a VOES.
You can install the fitting in the manifold,
I JBWeld a piece of brass tube into the manifold if it does not have a fitting.
Mount the switch with the port down and make the hose all downhill to the manifold so liquid does not condense in the hose.
Gotcha. Excuse my ignorance on this one. The VOES switch basically advances or retards the system based on rpm's (airflow through carb manifold) vs. the stock flyweights and springs?
It works different than flywheights more like vacuum advance
78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice78ironhead is just really nice
The part number 17622 is what my 79 came with when i bought it a couple of years ago, so far so good.
http://www.legendmcs.com/midusa-cata...01_Page_82.jpg
http://www.legendmcs.com/mid-usa-har...ignitions.html
