0 2016 48 Hesitating
Last Post: Screw Loose Dan
0 Ei
0 24633-77 Breather assembly
0 Newbie CV rebuild
Last Post: Matt Black
0 ‘68 XLCH...transmission
Last Post: Larry May
Last Post: Yochstein
Last Post: Jheitt
0 Salutations y'all
0 New member in MD
0 New from Utah
0 New England 2018
Old 31st December 2012
Freewheeler Freewheeler is offline
Sportster/Buell Model: 1977 Ironhead
Freewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to beholdFreewheeler is a splendid one to behold
Default Ironhead build - Sissy bar thread
Afternoon,
I hope you all had a good christmas.
I made a start on my sissy bar/fender strut by gettig hold of some bailing wire from a neighbour. I fastened one end into the vice, the other into my drill and put a few turns into it to stiffen things up a bit.
After fiddling and farting around with a 7x5 numberplate template and a nice old vintage rear light that I got from an autojumble I came up with the following as a start -
Next step is to get a heat source, a tube cutter and some bar - I thought 1/4" would be thick enough (or maybe too thick),
What do you think?
Nick
77 Ironhead Electric Start only
Paughco Frame
Custom build
rejeanprimeau's Avatar
I'll use 1/2 inche for a solid sissy, 1/4 will bent with the wind.
hogmania hogmania is offline
Sportster/Buell Model #2: xlh
Sportster/Buell Year #2: 1977
hogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura abouthogmania has a spectacular aura about
at least 1/2 maybe even 5/8 but not a 1/4 would flex and bend way too easy.
Thanks, I wasn't intending to carry a passenger so that would make them more of a fender strut - I would have thought 1/4" would be enough for that - what do you reckon.
Nick
simeli simeli is offline
Sportster/Buell Year: 1970
Sportster/Buell Year #2: 69
Other Motorcycle Model: Sportster
Other Motorcycle Year: 70
simeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud ofsimeli has much to be proud of
1/4" is going to have a lot of flex to it and vibration could kill it pretty quick, a lot would depend on the wall thickness as well, but even a heavy walled 1/4" is going to have a lot of flex in it. I would look more at the 1/2" tubing and even then I would be tempted to insert a solid rod into the center at least from the frame to the fender mount.
With your low seat frame you have a lot of unsupported fender hanging in the air, I would think the more stable you can make it the better.
You could try 1/4" tubing with a solid rod inserted all the way through it and see if the amount of flex is reduced enough to use it.
Thanks for the advice, ill have a crack at it and let you know how I get on.
Nick
Old 1st January 2013
Hi there,
Have been busy this afternoon transferring thought into metal and came up with the following in 3/8 as that was all I had -
I am feeling pleased with my efforts. This was the second go after a steep learning curve and ballsing up the first one. I worked off the bailing wire template and simply marked where a bend was needed with my old dad's pipe cutter. I then used a Rothenberber Propane torch to heat the section until it was cherry red and hey ho. The first one had an extra bend which didn't really look needed, that was the trouble with using bailing wire - too easy to bend!
Ill take some pictures of the whole bike from the side when I get the chance to do so. I also intend to make another shorter version just to see what it will look like.
I hope these pictures are of interest.
Nick
IronHead78's Avatar
IronHead78 IronHead78 is offline
Sportster/Buell Year: 78
IronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura about
Looks like you are well on your way, looking good.
78 sportster, Weisco pistions,Andrews Y cams, Kibblewhite valves with Manley springs, ported and polished heads with an SS super E.
Originally Posted by Freewheeler View Post
... I hope these pictures are of interest ...
Stuff you fabricate yourself is always of high interest on this forum.
I think you did a great job on it. The 3/8" stock looks a lot more substantial then the 1/4" would have, did you use solid stock or tubing?
