Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Last Post: x1_guy
0 Manifold Leaks Gone !!!!
0 Masking stripes
Last Post: shooterj2003
0 no rear brake light
0 2016 48 Hesitating
0 Ei
Old 18th January 2013
potatoe potatoe is offline
potatoe is an unknown quantity at this point
Default how to check oil level
hello everyone. im new to working on these. this is a 1000 ironhead, and i think it originally had an oil tank with dip stick. but now that gone with aftermarket tank and no dip stick. how can i check the oil level in the motor to make sure theres not enough or too much oil in there? thanks
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
As long as you can see oil in the filler hole around about 3/4 full, or no fuller than about an inch or so from the top it should be ok.
Doc308 Doc308 is offline
Sportster/Buell Year: 1959
Other Motorcycle Model: Panhead EL
Other Motorcycle Year: 1948
Doc308 is just really niceDoc308 is just really niceDoc308 is just really niceDoc308 is just really niceDoc308 is just really niceDoc308 is just really niceDoc308 is just really niceDoc308 is just really niceDoc308 is just really niceDoc308 is just really niceDoc308 is just really nice
Be sure that the oil level is not higher than the return or breather lines on the tank.
Old 19th January 2013
brucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud of
good call Doc308.
Old 20th January 2013
ok thanks. but how about when the motor is drained of oil and tank emptied for oil change? should i just add oil to tank or should i take small screw cap off of primary cover and add some oil into engine also.
i never worked on motors with a seperate oil tank. im trying to understand how the tank lets just enough oil in and out of motor without over filling or underfilling it.
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
Default Sportser Oiling
there is a Spring Loaded Stainless Ball Check Valve within the Oil Pump, see that Hex Fitting at the front of your Oil Pump? the spring and ball check are within... Oil that made it's pass thru the motor gets returned back to the Oil tank...
Service Manual and Parts Manual would be cool to purchase
Cycle World Oct 1962:
For an engine oil change, just top off the oil tank with the proper amount of oil.
Run the engine for awhile and check the level--it shouldn't change much.
If the bike has been sitting for a long while without any oil in it, I'd squirt some oil into the cylinders before the first start-up. Also, I'd kick the bike over a good ten times or more ( without starting it), so as to circulate oil throughout the system before starting it. If it's an electric start bike, disconnect the spark plug wires and crank the starter for a short while--once again, to circulate oil before starting up.
I believe that adding oil to the primary case is primarily for transmission lubrication--for older Sportsters anyway.
... but how about when the motor is drained of oil and tank emptied for oil change? should i just add oil to tank or should i take small screw cap off of primary cover and add some oil into engine also.
The engine oil is in the tank whenever the engine is not running. The primary oil is separate.
The engine takes 3 quarts with a stock oil tank, for most years. The primary takes 1,1/2 pints = 24 fl oz. Older IronHeads use the same type of oil in both; newer IronHeads use HD Formula+ in the primary. Yours is a newer model in this regard.
You need both of these manuals. Order from local indie shop, HD dealer, J&P Cycles, various eBay and internet sellers. Just put the part numbers into the Google and eBay searches.
Factory Service Manual 99484-85
Factory Parts Catalog 99451-85A
