0 My '05 1200C (insert clever title here)
Last Post: Ranchero50
0 Coil suggestions please!!!
0 Starter Worked, Then It Didn't
Last Post: VintageVinny
0 Home Brewing
0 This place still sucks!!!
0 V.o.e.s
0 05 sportster custom and bassani road rage
0 2009 Iron 883 Wont Start!
0 Rear sprockets
Last Post: 85IRONDIRT
0 Crank position sensor problems ??
0 07 883 Low .... lifting
0 Pictures of Evos that look Like Ironheads
Last Post: hotrodbiker
0 Rear shocks ?
Last Post: wachuko
Last Post: WKNDZ
Last Post: SLW210
0 Speedo fog
0 Oil pressure switch testing
Last Post: Mission1
0 Best seat for long rides
kav2ivan (61), Hunt (54), bikerjim67 (54), twenty2 (42), slimstyle05 (41), PatrickSwayz (35), Mwaggoner
Old 25th March 2013
il67bp's Avatar
il67bp il67bp is offline
il67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to allil67bp is a name known to all
Default kickstand spring replacement (what i did)
figured i could help someone save money so heres what happened to me. when i first got my 2008 sportster nightster in 2009 it had 2000 miles and the kickstand sagged. i dealt with it for years before i just went to harley and got a new spring. $20 what a rip off but i used it anyway and still had sag so i called the dealer and they said i needed another kickstand part (the bushing) frustrated i said forget it and just dealt with the sag and drag again. recently while the bike was on the lift i bent the spring to the point where it was sagging too much to even lean a little bit in a turn. i headed to home depot to find something i could use. i took a chance and got the one pictured below. 2 pack for $5 and its perfect. it does touch the nut as seen in pic but i doubt that will be an issue. hope this helps.
just a quick little tip for anyone changing it. may seem obvious but it wasnt to me at first..
1. when installing the new spring heres what i did. have someone hold the bike off the kickstand as straight as possible on the exhaust side.
2. let the kick stand back up
3. take old spring off. frame side first then kickstand side. ( mine was easy because it was so loose)
4. put the new spring on the kickstand side first then stretch it to the frame side and slide from bottom to the groove while making sure the kickstand is pressed firmly against the rubber stop.
hope this is clear
Last edited by il67bp; 26th March 2013 at 05:01.. Reason: added how i installed the spring
Old 25th March 2013
ReddTigger's Avatar
ReddTigger ReddTigger is online now
COOL, always nice to see a local improvement.
how long are the springs ???
States I've Ridden in
71.3 hp 70.8 tq
Old 25th March 2013
il67bp's Avatar
Damn I thought it was in the pic.. I don't have the package on me right now but I'll check.. BTW I'm pretty sure that says the working load is 61 pounds
Old 25th March 2013
il67bp's Avatar
Not nut but bushing* it touches
Old 25th March 2013
ReddTigger's Avatar
NEVERMIND a quick search of homedepot shows them at 4"
http://www.homedepot.com/p/Everbilt-...5608/202045475
Old 26th March 2013
fox4 fox4 is offline
fox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the roughfox4 is a jewel in the rough
My kickstand sags like crazy and I drag it really bad in turns. Just picked these springs up from my local Home Depot tonight, and I'm planning to install this weekend. Thanks OP!
Old 26th March 2013
il67bp's Avatar
Awesome it should work great! Now that I think about it does anyone know if there are any differences in springs between the different sportster models?
Old 26th March 2013
JohnK's Avatar
JohnK JohnK is offline
Sportster/Buell Model: Dearly Departed XL1200C
Other Motorcycle Year: 2000
JohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant future
Nice fix! Don't ignore those bushings. They're a rip-off I know, but once they're worn through, the slot will be the next thing to wear, and then the floppy kickstand will be a permanent condition. Here's what mine looked like when I removed them after 8 years:
John from Windsor Ontario
'00 FXDL
Old 26th March 2013
il67bp's Avatar
How much are the bushings? What is a sign that they are going?if my kickstand is working very well now is that any sort of indicator?
Old 26th March 2013
vlmuke's Avatar
vlmuke vlmuke is offline
Other Motorcycle Model: Fat Bob
Other Motorcycle Year: 2015
vlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to beholdvlmuke is a splendid one to behold
There was a thread on bushing replacement last year you can get them at almost any industrial supply like MSC, Grainger, MacMaster Carr
for cheap.
I don't know it all Nor do I claim to
